Giriş
In the midst of the iPhone 4 craze, we became impatient and decided we needed to tear down a phone, you know, just to keep us in tip-top shape. And lo-and-behold, the Sony Ericsson Xperia X10 Mini E10i.
A big thanks to Brian at EDN for providing the phone for this teardown. Be sure to check out his Xperia X10 Mini Preview!
Neye ihtiyacın var
The Sony Ericsson Xperia X10 Mini E10i is the smaller version of the Sony Ericsson Xperia X10.
Tech Specs:
600 MHz Qualcomm MSM7227
256 MB RAM and 256 MB internal ROM (only 128 MB accessible)
2.6" color transflective TFT display with a resolution of 240 X 320 pixels.
5 Megapixel camera with autofocus
802.11 b/g Wireless + Bluetooth 2.1
The backside of the X10 Mini E10i is characterized by a smooth plastic rear case with openings for the camera, LED flash, and speaker.
The controls of the X10 Mini E10i are pretty standard.
The bottom of the X10 Mini E10i integrates a 3.5 mm headphone jack as well as a micro-USB port.
The top edge houses the power button.
The left side accommodates the volume and camera buttons, leaving the right side blank and featureless.
A thumbnail is all that is needed to remove the microSD card from its housing in the inner case.
The simple design of the Mini E10 allows most components to plug directly into the logic board. The only exception is the external microSD card slot.
A single T5 Torx screw and a few plastic clips are all that secure the antenna assembly to the inner case.
remember to take out the bottom two screws
Step 6, Can I buy somewhere the Antena or just that part.. My friend lost it xD
A couple more T5 Torx screws secure the rear inner case and logic board to the rest of the X10 Mini E10i.
Disconnect the battery connector from the logic board with the flat end of a spudger.
Pry up the SIM card socket connector and remove the rear inner case from the the logic board.
The 3.7V 950 mAh Li-Polymer battery allows for 4 hours of talk time.
Measuring 40 x 35 x 5.5 mm and weighing in at a scant 18 grams, the X10 Mini E10i's battery provides up to 360 hours of 3G standby time.
Bettary not charging
Big players on the board include:
A Qualcomm MSM7227 with 600 MHz application processing, 400 MHz modem processing, hardware accelerated 3D graphics, integrated Bluetooth 2.1 & GPS capabilities, and image/video encoding & decoding.
STMicroelectronics NANDCBR4N9
Skyworks SKY77336 GSM power amplifier module
Qualcomm PM7540 power management IC
Qualcomm RTR6285 UMTS RF transceiver with receive diversity and GPS
TriQuint TQM679002A WLAN Power Amplifier
Sensors near the top of the board face outward from the front of the phone near the earphone opening.
A proximity sensor turns off the touch screen when the phone is against your face.
A light sensor automatically adjusts the LCD brightness for optimal viewing in any lighting condition.
And just like that, the dark deed has been done.
Thanks, Sony, for keeping it simple.
For more information on this little guy, check out EDN's Xperia X10 Mini Preview.
Keep an eye on our Teardown page for the arrival of the highly anticipated iPhone 4.
14 Yorum
he great take apart, do you need to dissemble the whole phone to replace the power button cap?
More or less. It's been a while since I took this apart, but I think you'll have to take the logic board out (work up to step 9). Luckily, this phone is really straightforward to disassemble.
so you can't use BST-38 Size: (5.5 x 48 x 40 mm) battery instead that one you have on the picture (or BST-41 some sellers on Ebay say it is compatible) ???
Hi There
This is a fantastic guide, and has enabled me to get the battery out, does anyone know where on earth I can buy one of these, I have searched all the usual channels, google ebay etc, but can only find batteries for other models that look nothing like this.
Any help would be much appreciated
All the best - Trev
Hallo,
habe mir ein Akku gekauft bei GAME-SHOP-ONE.DE Art.139 für 9,99 € ist Original mit Rahmen.
GAME-SHOP-ONE.DE
Euskirchnerstr. 2
52351 Düren
Hoffe ich konnte dir helfen. Kannst du mir sagen wie ich das Akku mit Rahmen aus dem Gerät bekomme. Gerät habe ich schon
auseinander gebaut. Wäre toll, danke bitte Antwort an meine Mail Adresse. adler@ci01.de. DANKE.
Gruß aus Fulda
Matthias
its very helpfull!
do you need to dissemble the whole phone to replace the front cover of the display? is it secured to the inner case with screws
can u tell me where i can get a battery for this phone??please
I need sony xperia x10 mini
I need a new battery and screen fitted by others urgent
The best for you, and good job
hi, i just wanted to ask if what was the problem if may phone does charge, but just keep on blinking red, and starts up but it won’t open..just on SE logo only?please help..thank u
