Neye ihtiyacın var
Push the trigger arm inwards to get the disk tray in the "injected mode".
Gently lift the retaining clip.
Then move the head stop to the rear of the drive to remove it.
Unscrew the Eject Motor Assembly.
Gently unplug it's connector.
Lift the Motor Assembly up and remove it.
Remove the retaining washers (be careful not to loose them!)
Lift the Slide Plate up and remove it entirely.
Remove the two brass screws.
Gently unplug the Stepper Motor Assembly and remove it.
Gently unplug the Head Assembly.
Unscrew the black screws to remove the Slide-guide shaft.
Unscrew …
… and remove the Switch PCB.
Desolder …
… unclip …
… remove PCB carefully, not to break the delicate switch.
Open the eject motor.
If your motor is of the old design and held together using clips, bend one clip using tweezers or a long flat blade scredriver.
Remove the big eject wheel by pinching the clip and pushing through the connecting rod.
Remove the other gears.
