Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. PlayStation 2 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sony PlayStation 2 Teardown, Sony PlayStation 2 Teardown: adım 1, 3 resimden 1. Sony PlayStation 2 Teardown, Sony PlayStation 2 Teardown: adım 1, 3 resimden 2. Sony PlayStation 2 Teardown, Sony PlayStation 2 Teardown: adım 1, 3 resimden 3.
    • On the front right side of the console we have the On/Off and the Eject button for the DVD player.
    • On the front left side we can see the two USB ports and the Firewire port. Two memory card slots, and the two controllers inputs.
    With a network adapter its possible to use a HDD with the PS2 … I asume it is a normal SATA HDD ?
    What is the maximum size this HDD can have ? … I asume that at least more than 2TB is too much ?
    MEX - Yanıt
  2. Sony PlayStation 2 Teardown: adım 2, 3 resimden 1. Sony PlayStation 2 Teardown: adım 2, 3 resimden 2. Sony PlayStation 2 Teardown: adım 2, 3 resimden 3.
    • Let's start with the teardown!
    • First of all we need to remove the Network Adaptor, which also gives you the choice to install a HDD.
    • The third picture shows where the hard disk would be placed.
  3. Sony PlayStation 2 Teardown: adım 3, 3 resimden 1. Sony PlayStation 2 Teardown: adım 3, 3 resimden 2. Sony PlayStation 2 Teardown: adım 3, 3 resimden 3.
    • This is the network adaptor we just removed, let's take a look at it before we move on to the console..
  4. Sony PlayStation 2 Teardown: adım 4, 3 resimden 1. Sony PlayStation 2 Teardown: adım 4, 3 resimden 2. Sony PlayStation 2 Teardown: adım 4, 3 resimden 3.
    • Turn the console upside down and with a flathead screw remove the rubber covers that hide the 8 screws.
    • On the back right of the console we can clearly see the warranty seal... the point of no return!
    • Once the seal and the screws are gone lift the upper part of the console and get ready to uncover the secrets of the PS2.
  5. Sony PlayStation 2 Teardown: adım 5, 3 resimden 1. Sony PlayStation 2 Teardown: adım 5, 3 resimden 2. Sony PlayStation 2 Teardown: adım 5, 3 resimden 3.
    • First of all let's remove the power supply by removing the four screws. In the blue box you can see the large fan, which is in front of the power supply to make sure the temperature is kept as low as possible, and to protect the "Emotion Engine".
    • Here's a closer look at the massive power supply.
  6. Sony PlayStation 2 Teardown: adım 6, 3 resimden 1. Sony PlayStation 2 Teardown: adım 6, 3 resimden 2. Sony PlayStation 2 Teardown: adım 6, 3 resimden 3.
    • Here is what is left when the power supply is gone.
    • Now we can easily remove the protective case for the optional hdd.
    • Done that we can unlock the optical drive from the metal frame.
  7. Sony PlayStation 2 Teardown: adım 7, 3 resimden 1. Sony PlayStation 2 Teardown: adım 7, 3 resimden 2. Sony PlayStation 2 Teardown: adım 7, 3 resimden 3.
    • Next we need to remove the plastic layer that protects the power supply so we can access to the screws beneath it.
    • Once all the screws are gone we can lift the metal frame by using a flathead screw and some leverage to unlock all four sides from the plastic case of the optical drive.
  8. Sony PlayStation 2 Teardown: adım 8, 3 resimden 1. Sony PlayStation 2 Teardown: adım 8, 3 resimden 2. Sony PlayStation 2 Teardown: adım 8, 3 resimden 3.
    • Before revealing the heart of our PS2 we need to remove the massive heat sink that prevents the "Emotion Engine" from overheating.
    • A closer view of the beautiful heat sink.
    • One last thing before removing the metal frame is unplugging the fan from the circuit board.
  9. Sony PlayStation 2 Teardown: adım 9, 3 resimden 1. Sony PlayStation 2 Teardown: adım 9, 3 resimden 2. Sony PlayStation 2 Teardown: adım 9, 3 resimden 3.
    • Here is the bottom part of the circuit board.
    • Some pictures of the board.
  10. Sony PlayStation 2 Teardown: adım 10, 3 resimden 1. Sony PlayStation 2 Teardown: adım 10, 3 resimden 2. Sony PlayStation 2 Teardown: adım 10, 3 resimden 3.
    • More pictures
  11. Sony PlayStation 2 Teardown: adım 11, 3 resimden 1. Sony PlayStation 2 Teardown: adım 11, 3 resimden 2. Sony PlayStation 2 Teardown: adım 11, 3 resimden 3.
    • Before flipping the board and see where all the fun takes place we need to unplug a few connectors that transport data form the circuit board to the optical drive.
  12. Sony PlayStation 2 Teardown: adım 12, 3 resimden 1. Sony PlayStation 2 Teardown: adım 12, 3 resimden 2. Sony PlayStation 2 Teardown: adım 12, 3 resimden 3.
    • And here it is... the EE "Emotion Engine" Some specifics about the EE: CPU 128 Bit running at 300 MHz
    • RDRAM 32 MB
    • The GS "Graphics Synthesizer" with its clock frequency of 150 MHz, DRAM Bus Bandwidth 48 GB per second, DRAM Bus width 2560 bits and a Maximum Polygon Rate of 75 million polygons per second... pretty impressive
  13. Sony PlayStation 2 Teardown: adım 13, 3 resimden 1. Sony PlayStation 2 Teardown: adım 13, 3 resimden 2. Sony PlayStation 2 Teardown: adım 13, 3 resimden 3.
    • A look at one of the two RDRAM of the PS2..
    • ..at the USB and Firewire ports..
    • ...and more pictures.
  14. Sony PlayStation 2 Teardown: adım 14, 3 resimden 1. Sony PlayStation 2 Teardown: adım 14, 3 resimden 2. Sony PlayStation 2 Teardown: adım 14, 3 resimden 3.
    • One last thing to take a look at is the optical drive...
  15. Sony PlayStation 2 Teardown: adım 15, 2 resimden 1. Sony PlayStation 2 Teardown: adım 15, 2 resimden 2.
    • On the side of the DVD player there's a little battery that helps the PS2 to keep up with date and time even when not plugged in... not bad..
    • There's a look at the bottom side of the optical drive.
    there is a lifespan of 8 year with lithium battery installed in ps2 consoles
    james fonovic - Yanıt
  16. Sony PlayStation 2 Teardown: adım 16, 3 resimden 1. Sony PlayStation 2 Teardown: adım 16, 3 resimden 2. Sony PlayStation 2 Teardown: adım 16, 3 resimden 3.
    • Unfortunately our teardown is over, it was really fun, hope you enjoyed it too.
matte18
405 İtibar
2 adet Kılavuz yazıldı
2 Yorum
I found there were some details lacking in this teardown, and as soon as I removed the top half of the case, I realised my PS2 was quite different inside. I did my own teardown with pix. Want it?
kitadran - Yanıt
Yes please; can you upload the pictures please
Justin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 78
Son 30 gün: 472
Her zaman: 71,425
