Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Sony SRS-X3 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown, Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 1, 2 resimden 1. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown, Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 1, 2 resimden 2.
    • There are 6 screws under the rubber feet on the bottom. Removing them allows the bottom plate to be removed, and then from there, the front panel, front cover, and battery compartment.
    • if you need higher reslution photos please leave a comment.
  2. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 2, 3 resimden 1. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 2, 3 resimden 2. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 2, 3 resimden 3.
    • Photos of the Main PCB. IC part numbers can be read off the photos.
    • DC to DC power supply and Yamaha audio amp chip/output filter inductors are the main parts of this side
  3. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 3, 3 resimden 1. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 3, 3 resimden 2. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 3, 3 resimden 3.
    • More images of the main board assembly.
    • The pinouts of the main flex are actually stated on the board which is a huge plus.
    • A CSR Bluetooth SoC and MXIC flash are provided.
  4. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 4, 2 resimden 1. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 4, 2 resimden 2.
    • The battery pack is on a connector and can be removed before all of this is taken out.
    • Battery is a 2 cell 18650 pack with protection built in; 7.4V
  5. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 5, 2 resimden 1. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 5, 2 resimden 2.
    • Two 7W speakers with strong magnets are included in this speaker; it is marketed with a 20W power output. Excursion is about 7-10mm at its peak.
  6. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 6, 2 resimden 1. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: adım 6, 2 resimden 2.
    • Two passive radiators are present inside the device. They're fairly heavy but rubberized, and they resonate and are tuned for low frequency reproduction. These move a LOT when it's playing. 7-10mm per side.
Larry Chen
913 İtibar
5 adet Kılavuz yazıldı
10 Yorum
This is great, thank you Larry. I'd wondered about the possibility of upgrading the battery to one that lasts longer between charges but I had no idea how to open the case. It didn't occur to me that the screws would be under the rubber feet!
Steve MacDonald - Yanıt
Dear Larry, can you give me capture specific card power close to battery. Because i got resistor blown in that card, and i don't know specific value of this resistor. Many Thanks in advance
didi - Yanıt
One speaker started to give a lot of distortion making it unusable. Repositioned speaker in the heavy (magnet) housing and it's all good again.
Thank you for the opening tips and pics!
Albert - Yanıt
Larry,
My mini connector for dc into the board has broken. Replace connector or the whole Board? Where can I get a Power Board?
michael ruse - Yanıt
Where could I find the replacement speaker? My right speaker is buzzing a little on certain songs. Thanks!
Aaron Todd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 8,694
