Ana içeriğe geç
Giriş
This is a full teardown of the Sony Vaio PCG-6J2L laptop computer. This guide provides detailed photographs and steps to taking apart and repairing the laptop.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged before performing any maintenance on the system.
Bu teardown bir tamir kılavuzu değildir. Sony Vaio PCG-6J2L cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Turn the laptop upside down. Locate the battery.
    • Turn the laptop upside down.
    • Locate the battery.
    • Unlock the battery by shifting the 'lock' slide to the 'unlock' position on the underside and back of the system.
    • Hold the release on the right side and remove the battery out carefully.
  2. Remove the four screws from the heat sink panel with the phillips screwdriver. Unscrew the two screws from the memory panel with the phillips screwdriver. Remove both panels and set aside.
    • Remove the four screws from the heat sink panel with the phillips screwdriver.
    • Unscrew the two screws from the memory panel with the phillips screwdriver.
    • Remove both panels and set aside.
    • Be careful with the heatsink, as this can be messy if handled improperly. It is a copper heat pipe.
  3. Lift the film covering to reveal the memory modules with the tweezers. Pull the tabs on both sides of the RAM away from the module. The module will pop up. Repeat these step for the other RAM module located above the RAM module previously removed and set aside.
    • Lift the film covering to reveal the memory modules with the tweezers.
    • Pull the tabs on both sides of the RAM away from the module. The module will pop up.
    • Repeat these step for the other RAM module located above the RAM module previously removed and set aside.
  4. Using a Philips screw driver, unscrew the rear keyboard screw from the bottom of the laptop.
    • Using a Philips screw driver, unscrew the rear keyboard screw from the bottom of the laptop.
  5. Push the tabs shown on both sides and the keyboard will pop up. A small flat-head might help you push the tabs.
    • Push the tabs shown on both sides and the keyboard will pop up.
    • A small flat-head might help you push the tabs.
    • Move the keyboard toward the mouse pad and gently pull up.
  6. Caution: there is a ribbon cable attached to the keyboard. It will break easily. Gently disconnect the ribbon cable by sliding down the tabs.
    • Caution: there is a ribbon cable attached to the keyboard. It will break easily.
    • Gently disconnect the ribbon cable by sliding down the tabs.
    • Gently take out the keyboard.
  7. Unscrew the two securing screws indicated. Carefully lift the heatsink out of the system with the tweezers and set it aside.
    • Unscrew the two securing screws indicated.
    • Carefully lift the heatsink out of the system with the tweezers and set it aside.
  8. Caution: DO NOT touch the gold connectors on the cpu, as this may damage your processor. Turn the securing screw on top of the CPU housing bracket counter-clockwise on the unlock position. Gently lift the CPU out of the system with tweezers and set aside in a safe place.
    • Caution: DO NOT touch the gold connectors on the cpu, as this may damage your processor.
    • Turn the securing screw on top of the CPU housing bracket counter-clockwise on the unlock position.
    • Gently lift the CPU out of the system with tweezers and set aside in a safe place.
  9. Remove the three screws from the front mouse panel. Lift the mouse assembly just enough to access the connecting ribbon cable. Lift the ribbon cable lock to remove the cable.
    • Remove the three screws from the front mouse panel.
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  10. Remove the securing screw on the bottom left of the optical drive. Carefully slide the optical drive to the right.
    • Remove the securing screw on the bottom left of the optical drive.
    • Carefully slide the optical drive to the right.
    • The IDE connector on the left will pop out.
  11. Disconnect the antennae from the wireless card. Pull back the tabs on the right of the wireless card until the card disconnects and pops up. Remove the wireless card and set aside.
    • Disconnect the antennae from the wireless card.
    • Pull back the tabs on the right of the wireless card until the card disconnects and pops up.
    • Remove the wireless card and set aside.
  12. Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel. To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off. Before proceeding, remove all black tape holding down wires and other cabling.
    • Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
    • To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
    • Before proceeding, remove all black tape holding down wires and other cabling.
  13. First pop off the antenna using a pair of tweezers. Use a Philips screw driver to unscrew the screw holding the board in place.
    • First pop off the antenna using a pair of tweezers.
    • Use a Philips screw driver to unscrew the screw holding the board in place.
    • Remove the board using a pair of tweezers.
  14. Remove the seven philips screws holding the speaker assembly in place.
    • Remove the seven philips screws holding the speaker assembly in place.
    • Disconnect the ribbon cable located at the top left corner of the assembly.
  15. Caution: Be careful of snags when pulling up assembly and speakers. To remove the VGA cable, lift up on the metal bracket and gently lift the connector off the logic board.
    • Caution: Be careful of snags when pulling up assembly and speakers.
    • To remove the VGA cable, lift up on the metal bracket and gently lift the connector off the logic board.
    • To remove the webcam cable, lift up the connector from the logic board gently.
  16. This is where your Hard Drive is located.
    • This is where your Hard Drive is located.
    • Remove the three harddrive securing screws.
    • The Serial ATA (SATA) hard drive is located where the yellow box indicates in the picture.
  17. Remove all screws holding the keyboard tray to the laptop. Lift the cover off the console and set aside.
    • Remove all screws holding the keyboard tray to the laptop.
    • Lift the cover off the console and set aside.
  18. Caution: Be careful of snags when pulling up assembly and speakers.
    • Remove bluetooth, speaker, webcam assembly. This is one unit and will come out together.
  19. Unscrew the four securing screws, two on each side of the LCD. Carefully remove the LCD Carefully remove the LCD
    • Unscrew the four securing screws, two on each side of the LCD.
    • Carefully remove the LCD
  20. Remove all the screws securing the keyboard tray.
    • Remove all the screws securing the keyboard tray.
    • Remove keyboard tray.
  21. Caution: When removing the fan, be careful to not tear the attached ribbon cable. Unscrew and remove the internal fan.
    • Caution: When removing the fan, be careful to not tear the attached ribbon cable.
    • Unscrew and remove the internal fan.
    • Unscrew and remove the logic board from the backing.
David Hoyt
3.919 İtibar
43 adet Kılavuz yazıldı
Takım
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G89
4 Üyeler
52 adet Kılavuz yazıldı
Bir Yorum
Does this work with the PCG 9J5L
frederick200147 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 67
Her zaman: 37,018
