Giriş
This is a full teardown of the Sony Vaio VGN-SZ120P laptop computer. This guide provides detailed photographs and steps to taking apart and repairing the laptop.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged before performing any maintenance on the system.
Neye ihtiyacın var
Turn the laptop upside down.
Locate the battery.
Unlock the battery by shifting the 'lock' slide to the 'unlock' position on the underside and back of the system.
Hold the release on the right side and remove the battery out carefully.
Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
Before proceeding, remove all black tape holding down wires and other cabling.
Remove the seven philips screws holding the speaker assembly in place.
Disconnect the ribbon cable located at the top left corner of the assembly.
Only 2 screws, the others come from the bottom and secure the plastic shield removed 2 steps before this,
also 1 of the marks is a push-button...
2 Yorum
Does this work with the PCG 9J5L
