Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Sony Walkman WM-4 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: adım 1, 2 resimden 1. Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: adım 1, 2 resimden 2.
    • Flip the Sony Walkman so that its rear side faces you.
    • Use a screwdriver to remove the two screws from the surface of the Walkman.
    • Press the battery plate slightly with your thumb and slide it downwards. This will open the battery compartment.
    • Remove the batteries from the Walkman.
  2. Sony Walkman WM-4 Teardown: adım 2, 2 resimden 1. Sony Walkman WM-4 Teardown: adım 2, 2 resimden 2.
    • Turn over your Walkman and gently press the cover to open the cassette holder.
    • When the cassette holder is opened, you can see two more screws.
    • Using a screwdriver, remove the two screws.
  3. Sony Walkman WM-4 Teardown: adım 3, 2 resimden 1. Sony Walkman WM-4 Teardown: adım 3, 2 resimden 2.
    • Use a plastic opening tool or a spudger to push the tabs. This will remove the cover and open the Walkman.
    • Be careful so you dont break the tabs!
    • Once the Walkman is opened, you can troubleshoot for any issues, remove the old wires and attach new ones, or even reassemble the Walkman.
lenzo
125 İtibar
1 Kılavuz yazıldı
Bir Yorum
Drive belt trashed any ideas where to get one?
nz-tiger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 16,335
