Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Sony Walkman WM-FX20 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sony Walkman WM-FX20 Teardown, Sony Walkman WM-FX20 Teardown: adım 1, 1 resimden 1.
    • Good Ole Sony Walkman.
    Make sure both batteries have been removed before you start opening the housing.
    Reiner E. Kreitner - Yanıt
  2. Sony Walkman WM-FX20 Teardown: adım 2, 3 resimden 1. Sony Walkman WM-FX20 Teardown: adım 2, 3 resimden 2. Sony Walkman WM-FX20 Teardown: adım 2, 3 resimden 3.
    • Start with removing the screw on the Underside. The screw on the Backside next. Then the two on the reverse side of the tape controls.
    • New line.
  3. Sony Walkman WM-FX20 Teardown: adım 3, 3 resimden 1. Sony Walkman WM-FX20 Teardown: adım 3, 3 resimden 2. Sony Walkman WM-FX20 Teardown: adım 3, 3 resimden 3.
    • With a small Phillips head, Pry the sides carefully.
  4. Sony Walkman WM-FX20 Teardown: adım 4, 2 resimden 1. Sony Walkman WM-FX20 Teardown: adım 4, 2 resimden 2.
    • Take care not to jostle the Switches on the top of the unit while removing case. So now we have removed the underside casing from the device.
  5. Sony Walkman WM-FX20 Teardown: adım 5, 3 resimden 1. Sony Walkman WM-FX20 Teardown: adım 5, 3 resimden 2. Sony Walkman WM-FX20 Teardown: adım 5, 3 resimden 3.
    • Find Ribbon Cable that connects to the board. Carefully Pry open either side of connector as shown, then remove ribbon cable from board.
  6. Sony Walkman WM-FX20 Teardown: adım 6, 1 resimden 1.
    • Now we can remove the board from the casing.
  7. Sony Walkman WM-FX20 Teardown: adım 7, 3 resimden 1. Sony Walkman WM-FX20 Teardown: adım 7, 3 resimden 2. Sony Walkman WM-FX20 Teardown: adım 7, 3 resimden 3.
    • If you do not need to replace the front door control assembly I would not suggest to continue any further- That little spring took me a good 40 minutes to properly get back in place. It is Crucial to get it in right so that the Cassette door stays flush and closed.
    • Find Door Spring and remove carefully. Then find and pry off (on either side) glued on bumpers- These limit the distance the door hinge can travel in order to be pulled off---
  8. Sony Walkman WM-FX20 Teardown: adım 8, 2 resimden 1. Sony Walkman WM-FX20 Teardown: adım 8, 2 resimden 2.
    • Now gently pry the door hinges on either side off of their pivot point, and remove the front door from the assembly
  9. Sony Walkman WM-FX20 Teardown: adım 9, 3 resimden 1. Sony Walkman WM-FX20 Teardown: adım 9, 3 resimden 2. Sony Walkman WM-FX20 Teardown: adım 9, 3 resimden 3.
    • Remove three screws on backside of cassette door. Then remove panel.
  10. Sony Walkman WM-FX20 Teardown: adım 10, 3 resimden 1. Sony Walkman WM-FX20 Teardown: adım 10, 3 resimden 2. Sony Walkman WM-FX20 Teardown: adım 10, 3 resimden 3.
    • There is your front mounted control board! It is attached to what appears to be a speaker i'm guessing. Possibly for the alarm clock. I found that to be interesting, the little speaker thing. Anyways , thats it.
JaosnT
414 İtibar
5 adet Kılavuz yazıldı
5 Yorum
Please provide more info on how to put the spring back together again. I have a WM-FX435.
Robert Surya - Yanıt
Hi, the casette operation has failed. Now I try to check. Really I do not the reason. Any suggestion?
Batur Salamom - Yanıt
Thank you, my fx 20 is now like new :) Great tutorial!
kolev_art - Yanıt
Exactly what I needed to change the drive belts, which turned out to be super easy using these directions and excellent pictures. Thank you so much!
Tek Trekker - Yanıt
Great guide, much appreciated!
Makes a clean and belt change doable.
43578UMP - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 101
Her zaman: 25,098
