Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Sony Xperia Z4 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Remove back cover. Remove back cover.
    • Remove back cover.
    How much heat needed to melting down the back cover adhesive…
    Aspar Riansyah - Yanıt
    it is no need to heat too much.
    KK0902 -
  2. Remove battery. Remove battery. Remove battery.
    • Remove battery.
  3. Release all the connectors on board and remove the screws there. Release all the connectors on board and remove the screws there.
    • Release all the connectors on board and remove the screws there.
  4. Remove that small securing bracket. Remove that small securing bracket.
    • Remove that small securing bracket.
  5. Remove rear camera and front camera. Remove rear camera and front camera. Remove rear camera and front camera.
    • Remove rear camera and front camera.
  6. Remove motherboard. Remove motherboard.
    • Remove motherboard.
  7. Remove sensor flex. Remove sensor flex. Remove sensor flex.
    • Remove sensor flex.
  8. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  9. Remove two pieces of cover brackets on the audio jack. Remove two pieces of cover brackets on the audio jack. Remove two pieces of cover brackets on the audio jack.
    • Remove two pieces of cover brackets on the audio jack.
  10. Cut the adhesive on the top of the audio jack and remove the audio jack assembly. Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
    • Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
  11. Remove signal cable.
    • Remove signal cable.
  12. Release connectors connecting on the antenna logic board and finally remove it. Release connectors connecting on the antenna logic board and finally remove it. Release connectors connecting on the antenna logic board and finally remove it.
    • Release connectors connecting on the antenna logic board and finally remove it.
  13. Release LCD connector there and loosen the bottom of the whole flex. Release LCD connector there and loosen the bottom of the whole flex.
    • Release LCD connector there and loosen the bottom of the whole flex.
  14. Remove main flex. Remove main flex. Remove main flex.
    • Remove main flex.
  15. Remove loudspeaker securing bracket. Remove loudspeaker securing bracket.
    • Remove loudspeaker securing bracket.
  16. Remove loudspeaker hidden under the flex. Remove loudspeaker hidden under the flex.
    • Remove loudspeaker hidden under the flex.
  17. Push the USB port out of the slot. Push the USB port out of the slot.
    • Push the USB port out of the slot.
  18. Remove USB charging flex assembly. Remove USB charging flex assembly.
    • Remove USB charging flex assembly.
  19. Remove earpiece speaker. Remove earpiece speaker.
    • Remove earpiece speaker.
  20. Remove the metal bracket covering on the screen flex. Remove the metal bracket covering on the screen flex.
    • Remove the metal bracket covering on the screen flex.
  21. Remove LCD screen carefully. Remove LCD screen carefully. Remove LCD screen carefully.
    • Remove LCD screen carefully.
    Gerade so ein schwieriger Schritt, wie das Entfernen des Displays, bei dem auch echt viel schief gehen kann, sollte ruhig etwas detaillierter beschrieben werden. Die Mühe ist man der Community echt schuldig.
    Davon mal abgesehen ist das Bildmaterial echt gut gelungen!
    Gerdi - Yanıt
  22. Done.
    • Done.
Sophia
43.006 İtibar
62 adet Kılavuz yazıldı
2 Yorum
Is it possible to replace the nylon corners? I've heard it was possible in the previous xperia z devices like z2 and z3. Unfortunately I couldn't find the replacement corners for z3+ or z4 anywhere. Anyone has any idea about it?
Sanket - Yanıt
Late answer, but it seems like there’s replacement parts for the corners now. I don’t know how to replace them, though.
Farie Indriawan -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 55
Son 30 gün: 227
Her zaman: 30,877
