Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Squier Strat Guitar cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Squier Strat Guitar Teardown, Squier Strat Guitar Teardown: adım 1, 1 resimden 1.
    • Pull off the three tone/volume caps.
  2. Squier Strat Guitar Teardown: adım 2, 1 resimden 1.
    • Pull off the end cap on the pickup selector.
    • Note: This is not how the switch should normally look. This one is bent slightly; the tip should be pointing straight up.
  3. Squier Strat Guitar Teardown: adım 3, 1 resimden 1.
    • Unscrew the three bolts holding the tone/volume potentiometers to the scratch plate.
  4. Squier Strat Guitar Teardown: adım 4, 1 resimden 1.
    • Remove the 3 washers from the tone/volume potentiometers
  5. Squier Strat Guitar Teardown: adım 5, 1 resimden 1.
    • Unscrew the eight screws which hold the pick guard to the main body.
  6. Squier Strat Guitar Teardown: adım 6, 1 resimden 1.
    • Unscrew the two screws holding the pickup selector in place.
  7. Squier Strat Guitar Teardown: adım 7, 1 resimden 1.
    • unscrew the six screws holding the three pickups in place.
  8. Squier Strat Guitar Teardown: adım 8, 2 resimden 1. Squier Strat Guitar Teardown: adım 8, 2 resimden 2.
    • Lift off the scratch plate, revealing the electronics inside the main body
  9. Squier Strat Guitar Teardown: adım 9, 1 resimden 1.
    • Another method of dis-assembly: remove the pickguard screws (leaving pickup screws, pots and switch untouched).
    • Remove the jack plate, desolder or cut the output jack wires, flip over the guitar and desolder the ground wire on the tremolo. Remove the pickguard with all electronics attached.
    • This method gives easy access to do electronics repairs/mods, without having to readjust pickup heights and individual components won't move around when you're soldering.
  10. Squier Strat Guitar Teardown: adım 10, 1 resimden 1.
    • Lift off the three pickup covers.
  11. Squier Strat Guitar Teardown: adım 11, 1 resimden 1.
    • Remove the springs which were on the underside of the pickups.
  12. Squier Strat Guitar Teardown: adım 12, 1 resimden 1.
    • Unscrew the two screws holding the lead input cover in place and lift off the cover.
  13. Squier Strat Guitar Teardown: adım 13, 1 resimden 1.
    • Unscrew the input threaded bolt, which holds the output jack in place.
  14. Squier Strat Guitar Teardown: adım 14, 2 resimden 1. Squier Strat Guitar Teardown: adım 14, 2 resimden 2.
    • Unscrew the screw holding the bottom strap button in position.
  15. Squier Strat Guitar Teardown: adım 15, 1 resimden 1.
    • Carry out the same process to remove the top strap button.
  16. Squier Strat Guitar Teardown: adım 16, 1 resimden 1.
    • Remove the six screws securing the bridge to the body.
  17. Squier Strat Guitar Teardown: adım 17, 1 resimden 1.
    • Take out the six screws holding the white back plate in place.
  18. Squier Strat Guitar Teardown: adım 18, 1 resimden 1.
    • Remove the three tremolo springs from the spring claw and tremolo block.
  19. Squier Strat Guitar Teardown: adım 19, 1 resimden 1.
    • Unscrew the two screws holding the spring claw to the body.
  20. Squier Strat Guitar Teardown: adım 20, 1 resimden 1.
    • Remove Bridge from main body.
  21. Squier Strat Guitar Teardown: adım 21, 1 resimden 1.
    • Unscrew chrome parts.
  22. Squier Strat Guitar Teardown: adım 22, 3 resimden 1. Squier Strat Guitar Teardown: adım 22, 3 resimden 2. Squier Strat Guitar Teardown: adım 22, 3 resimden 3.
    • Undo the 6 screws holding the saddles to the bridge. Then remove the spring and unscrew the 12 threaded bars.
  23. Squier Strat Guitar Teardown: adım 23, 1 resimden 1.
    • Unscrew bridge from the tremolo block.
  24. Squier Strat Guitar Teardown: adım 24, 1 resimden 1.
    • Remove the four wood screws holding the neck to the body of the guitar.
  25. Squier Strat Guitar Teardown: adım 25, 1 resimden 1.
    • Pull neck away from main body.
  26. Squier Strat Guitar Teardown: adım 26, 1 resimden 1.
    • Unscrew the two small screws securing the string trees to the headstock.
  27. Squier Strat Guitar Teardown: adım 27, 1 resimden 1.
    • Unscrew the tuner bushings with a 10mm hex driver
  28. Squier Strat Guitar Teardown: adım 28, 1 resimden 1.
    • Push the tuners from the front to pop them loose. It make take a bit of force if the alignment peg is stuck. Some use screws instead.
  29. Squier Strat Guitar Teardown: adım 29, 1 resimden 1.
    • Remove the tension screw followed by the tuner button, metal and then fiber washer.
Guitar group
259 İtibar
1 Kılavuz yazıldı
10 Yorum
Awesome teardown! Keep up the good work!
Matthew Newsom - Yanıt
totally agree
lon -
Great for a "tear-down" per-se, but horrible first steps for anyone to use to get inside their Fender Strat.
To get inside, don't unscrew every screw from the surface as is described here. The faceplate of a Fender Strat (and many other guitars) holds all the electronics to itself, so you only need to undo the screws around the edges and then lift off the faceplate to get to everything inside. From here you can remove the components that matter and solder or re-wire as is necessary, and then replace the faceplate as a single unit.
The steps in this article will lead to far more work than is necessary if you plan on fixing or replacing aspects of the guitar.
Topher Kessler - Yanıt
when I pulled off the knobs they pulled out a metal pin and the pin will not come out of the knob and I cant get the knob and pin to go back in
nellasemaj2000 - Yanıt
I'm having the same problem. Does anyone know the fix or have you found a solution?
Manny OK -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 33
Son 30 gün: 104
Her zaman: 61,255
