Giriş
Hey im Marios!I Make repairs on everythink you may have in your house!This is an easy repair but some people may want some help!Lets go!
Neye ihtiyacın var
Remove the 2 screws holding the back cover!Should be fairly easy(You need a Phillips Screwdriver)
This is also fairly easy to do!You can use your hands to pull it off!Put first use a flat screwdriver to open the "clips"
Remove the cable antenna now!And thats it you are done,now just follow the guide in reverse and install your new wireless card/antenna if also needed!
WARNING:DO THIS CAREFULLY!ITS SUGGESTED THAT YOU DO THIS STEP SLOWLY!TAKE YOUR TIME OR YOU MAY DAMAGE THE CABLE OR EVEN THE BOARD!
