Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. TP-Link TL-WR802N N300 Nano Router cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. TP-Link TL-WR802N N300 Nano Router Teardown, TP-Link TL-WR802N N300 Nano Router Teardown: adım 1, 3 resimden 1. TP-Link TL-WR802N N300 Nano Router Teardown, TP-Link TL-WR802N N300 Nano Router Teardown: adım 1, 3 resimden 2. TP-Link TL-WR802N N300 Nano Router Teardown, TP-Link TL-WR802N N300 Nano Router Teardown: adım 1, 3 resimden 3.
    • Inside the device contains:
    • Speeds up to 300 Mbps; 2x2 MIMO antenna setup; 5 modes which can turn it into a WiFi extender, or a Wi-Fi client to connect wired only devices to Wi-Fi.
    • On the outside:
    • Green LED indicator
    • 10/100 Ethernet port; can be used as a WAN or LAN
    • Micro USB for power
    • Recessed Reset Button
  2. TP-Link TL-WR802N N300 Nano Router Teardown: adım 2, 3 resimden 1. TP-Link TL-WR802N N300 Nano Router Teardown: adım 2, 3 resimden 2. TP-Link TL-WR802N N300 Nano Router Teardown: adım 2, 3 resimden 3.
    • On the top of the router, there is a blue panel that is the case. It is held on by clips, holding it in place.
    • The top panel can be removed by using a small flat bladed screwdriver and inserting it into the gap between the case and the panel itself.
    • You have to use a little force, but not too much force as you'll break those clips!
  3. TP-Link TL-WR802N N300 Nano Router Teardown: adım 3, 2 resimden 1. TP-Link TL-WR802N N300 Nano Router Teardown: adım 3, 2 resimden 2.
    • Once the cover is loose, the cover can be removed, revealing the router's main circut board.
  4. TP-Link TL-WR802N N300 Nano Router Teardown: adım 4, 2 resimden 1. TP-Link TL-WR802N N300 Nano Router Teardown: adım 4, 2 resimden 2.
    • With the top panel removed, we can now see the internal components.
    • A spudger was used to lift the circuit board out of the case.
    • There was no room to wedge the board out of the case, so one of the antennas was used with the top of the spudger to lift the board out of the case.
  5. TP-Link TL-WR802N N300 Nano Router Teardown: adım 5, 1 resimden 1.
    • On the front of the board:
    • Qualcomm Atheros QCA9533-AL3A SoC
    • Running at a speed of 560 MHz
    • Uses the MIPS 24Kc architecture
    • Contains an integrated Ethernet switch and wireless radio built in.
    • 2 soldered antennas that allows a MIMO configuration of 2x2:2.
    • Most of the information that I can obtain are from Wikidevi at: https://wikidevi.com/wiki/Qualcomm_Ather...
  6. TP-Link TL-WR802N N300 Nano Router Teardown: adım 6, 3 resimden 1. TP-Link TL-WR802N N300 Nano Router Teardown: adım 6, 3 resimden 2. TP-Link TL-WR802N N300 Nano Router Teardown: adım 6, 3 resimden 3.
    • Back of the board:
    • Zentel A3S56D40GTP-50L RAM chip with 32 MB
    • Windond 25Q32FVS1 SOIC Flash chip with 8 MB
  7. TP-Link TL-WR802N N300 Nano Router Teardown: adım 7, 1 resimden 1.
    • And that's It!
    • The router in this teardown is v1.0. There is another version of the same router, called V2.0, which is virtually identical, however it will only accept firmware that was sold in that country.
    • For a very small device it can do alot! But it can do more if the OpenWrt/LEDE firmware was ported over.
    • Unfortunately, due to the limited amount of memory and RAM, OpenWrt and LEDE may not work as expected, as it expects more memory and RAM, therefore you can't turn it into say a OpenVPN client.
Peter Low
281 İtibar
2 adet Kılavuz yazıldı
8 Yorum
Is it possible to remove the 2 antennas and ad external antennas instead… and how Should it be done…
Best regards
Anders Bech - Yanıt
Hi
Is it possible to remove the 2 antennas and replace them with external antennas instead… and how should this be done…
Best regards
Anders Bech - Yanıt
i’m sure you can just how you do it i’m not sure
Luke -
This TP Link Router is awesome. I like it. i think we can add external antennas in it.
Hashley - Yanıt
flash openwrt
tianxiaobo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 101
Her zaman: 10,809
