Giriş
We are going to start with the base of the fan, and move to the top afterwords.
Neye ihtiyacın var
Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
Remove the two 10 mm Phillips #1 screws found connecting the switch to the case.
Release the 3 clips that attach the front fan guard to the rear fan guard.
At the base of the upper assembly there is a plug which conceals a screw.
The plug can be removed with a screwdriver. Removing the plug may take a few attempts.
Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
