Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Bu Teardown'da Kullanılan Aletler
Giriş
This teardown is done as to comply with the task 2 IDES 2171. Photographed and written by Ashley Mutandiro and Aisyah Azmi, first year students of Bachelor of Industrial Design UNSW Sydney, Australia.
Bu teardown bir tamir kılavuzu değildir. Toaster cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Breville Toaster.
    • Breville Toaster.
    • The toaster before the teardown process.
  2. Turn the toaster upside-down. Use the drill to unscrew the six slotted Spanner head screws Use the drill with corresponding screwdriver bit to remove the Truss Phillip screws
    • Turn the toaster upside-down.
    • Use the drill to unscrew the six slotted Spanner head screws
    • Use the drill with corresponding screwdriver bit to remove the Truss Phillip screws
    • The Slotted Spanner head screws hold the four rubber feet at the bottom of the casing.
  3. Unattach the four rubber feet.
    • Unattach the four rubber feet.
  4. Detach the timer knob using a flat head screw driver Remove the internal components from the red casing Remove the internal components from the red casing
    • Detach the timer knob using a flat head screw driver
    • Remove the internal components from the red casing
  5. Note: Red casing is still attached to the interior body of the toaster. Detach electric circuit housing from red casing Detach electric circuit housing from red casing
    • Note: Red casing is still attached to the interior body of the toaster.
    • Detach electric circuit housing from red casing
  6. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  7. Firstly, unscrew the four Pan Phillip head screws Then snap off the three welded plastic studs to detach the timer knob housing from the red casing
    • Firstly, unscrew the four Pan Phillip head screws
    • Then snap off the three welded plastic studs to detach the timer knob housing from the red casing
  8. Unfasten the two Pan Phillip head screws  to detach the buttons' housing Unfasten the two Pan Phillip head screws  to detach the buttons' housing Unfasten the two Pan Phillip head screws  to detach the buttons' housing
    • Unfasten the two Pan Phillip head screws to detach the buttons' housing
  9. Note: There are two housings attach to both side of the interior body of the toaster. Remove the two Pan Phillip head screws to detach the circuit board from the heat controller housing. Then, remove the slider as well.
    • Note: There are two housings attach to both side of the interior body of the toaster.
    • Remove the two Pan Phillip head screws to detach the circuit board from the heat controller housing.
    • Then, remove the slider as well.
  10. Remove the circuit board housing for the heat controller from the interior body of the toaster by unscrewing two Pan Phillip head screws Remove the cable fasteners using a flat head screw driver Remove the cable fasteners using a flat head screw driver
    • Remove the circuit board housing for the heat controller from the interior body of the toaster by unscrewing two Pan Phillip head screws
    • Remove the cable fasteners using a flat head screw driver
  11. Separate the interior body of the toaster from the bottom cover. Remove the screw caps Unscrew  the two Pan Phillip head screws to detach the aluminium vent
    • Separate the interior body of the toaster from the bottom cover.
    • Remove the screw caps
    • Unscrew the two Pan Phillip head screws to detach the aluminium vent
  12. Use pliers to break apart the welded wires from the interior body. Snip off the rest of the wires still attached to the interior body using a wire cutter Remove the circuit board from its housing
    • Use pliers to break apart the welded wires from the interior body.
    • Snip off the rest of the wires still attached to the interior body using a wire cutter
    • Remove the circuit board from its housing
  13. Separate the electric components from the interior body Separate the electric components from the interior body
    • Separate the electric components from the interior body
  14. Insert wisdom here.
    • Insert wisdom here.
Aisyah Azmi
217 İtibar
1 Kılavuz yazıldı
Bir Yorum
Don’t buy this toaster…They fail and Breville won’t warranty it after 1 year….
Never again Breville..
James Payne - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 105
Son 30 gün: 453
Her zaman: 7,496
