Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Toaster cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Teardown: Breville Toaster, Breville Toaster Teardown: adım 1, 1 resimden 1.
    • Breville Toaster.
    • The toaster before the teardown process.
  2. Teardown: Breville Toaster: adım 2, 3 resimden 1. Teardown: Breville Toaster: adım 2, 3 resimden 2. Teardown: Breville Toaster: adım 2, 3 resimden 3.
    • Turn the toaster upside-down.
    • Use the drill to unscrew the six slotted Spanner head screws
    • Use the drill with corresponding screwdriver bit to remove the Truss Phillip screws
    • The Slotted Spanner head screws hold the four rubber feet at the bottom of the casing.
  3. Teardown: Breville Toaster: adım 3, 1 resimden 1.
    • Unattach the four rubber feet.
  4. Teardown: Breville Toaster: adım 4, 3 resimden 1. Teardown: Breville Toaster: adım 4, 3 resimden 2. Teardown: Breville Toaster: adım 4, 3 resimden 3.
    • Detach the timer knob using a flat head screw driver
    • Remove the internal components from the red casing
    Is this indicating that the lever is pried off, or that a metal spring is being released by the screwdriver?
    David - Yanıt
  5. Teardown: Breville Toaster: adım 5, 3 resimden 1. Teardown: Breville Toaster: adım 5, 3 resimden 2. Teardown: Breville Toaster: adım 5, 3 resimden 3.
    • Note: Red casing is still attached to the interior body of the toaster.
    • Detach electric circuit housing from red casing
    There is also probably the grounding for the external case. This is a troublesome ribbon cable. I'm beginning to think that these students should have had more supervision in this teardown since they seem unaware of the risks involved in mains connected devices, when capacitors may be involved. It is possible that their model doesn't have case grounding but there is clearly a need for adult supervision.
    Senor Mambo - Yanıt
  6. Teardown: Breville Toaster: adım 6, 2 resimden 1. Teardown: Breville Toaster: adım 6, 2 resimden 2.
    • Firstly, unscrew the four Pan Phillip head screws
    • Then snap off the three welded plastic studs to detach the timer knob housing from the red casing
  7. Teardown: Breville Toaster: adım 7, 3 resimden 1. Teardown: Breville Toaster: adım 7, 3 resimden 2. Teardown: Breville Toaster: adım 7, 3 resimden 3.
    • Unfasten the two Pan Phillip head screws to detach the buttons' housing
  8. Teardown: Breville Toaster: adım 8, 3 resimden 1. Teardown: Breville Toaster: adım 8, 3 resimden 2. Teardown: Breville Toaster: adım 8, 3 resimden 3.
    • Note: There are two housings attach to both side of the interior body of the toaster.
    • Remove the two Pan Phillip head screws to detach the circuit board from the heat controller housing.
    • Then, remove the slider as well.
  9. Teardown: Breville Toaster: adım 9, 3 resimden 1. Teardown: Breville Toaster: adım 9, 3 resimden 2. Teardown: Breville Toaster: adım 9, 3 resimden 3.
    • Remove the circuit board housing for the heat controller from the interior body of the toaster by unscrewing two Pan Phillip head screws
    • Remove the cable fasteners using a flat head screw driver
  10. Teardown: Breville Toaster: adım 10, 3 resimden 1. Teardown: Breville Toaster: adım 10, 3 resimden 2. Teardown: Breville Toaster: adım 10, 3 resimden 3.
    • Separate the interior body of the toaster from the bottom cover.
    • Remove the screw caps
    • Unscrew the two Pan Phillip head screws to detach the aluminium vent
  11. Teardown: Breville Toaster: adım 11, 3 resimden 1. Teardown: Breville Toaster: adım 11, 3 resimden 2. Teardown: Breville Toaster: adım 11, 3 resimden 3.
    • Use pliers to break apart the welded wires from the interior body.
    • Snip off the rest of the wires still attached to the interior body using a wire cutter
    • Remove the circuit board from its housing
  12. Teardown: Breville Toaster: adım 12, 2 resimden 1. Teardown: Breville Toaster: adım 12, 2 resimden 2.
    • Separate the electric components from the interior body
  13. Teardown: Breville Toaster, Components of the Toaster Teardown: adım 13, 1 resimden 1.
    • Insert wisdom here.
    I advise against using a screwdriver to remove the darkness control knob. That risks scratches and cracking the knob or post. If you know that the item can be pulled out safely, I suggest using a loop of paracord. That spreads the stress along the entire knob.
    Senor Mambo - Yanıt
Aisyah Azmi
217 İtibar
1 Kılavuz yazıldı
11 Yorum
Don’t buy this toaster…They fail and Breville won’t warranty it after 1 year….
Never again Breville..
James Payne - Yanıt
Thank you for this tear down guide. Though it’s built pretty well and feels like a tank, It doesn’t seem very repairable. Mine stopped working a couple months ago and I’m contemplating throwing it out. Comments?
David Vileta - Yanıt
any chance you still have the electronics for the toaster. Mine stopped working. It’s not the heating element. I THINK the issue is one of the components on the circuit board failed. I’ll buy the harness with the PCB from you, if it’s still around. Thanks.
Riccardo - Yanıt
Thanks very much for posting all of this, gave me the confidence to 'go in'.
Foe anyone thinking of doing what I just did; the guts of a plastic cased model can be put into a metal cased model but there are a few differences but everything you need is there.
Sean Johnson - Yanıt
Purchased a Breville die cast 2 slice toaster ($160). After one year it stopped toasting evenly and then on the out side of one slice. I am capable of fixing this but Breville will not sell parts, they want you to buy a new one. My first and last Breville product.
Lou Viscomi - Yanıt
Mon Breville BTA830XL outrageusement cher ne grille qu'un coté du pain à la fois. On mets la moitié du temps sur un coté et on inverses les tranche de pain dans le fentes pour l'instant. Très difficile à ouvrir avec toute sortes de vis compliquées à dessin. Dernier Breville à vie, c'est un engagement. Ne sont pas plus durable qu'un grille pain bas de game. Trop de fonctionnalités sans la qualité.
Josée Schepper - Yanıt
My family likes this toaster quite a bit, but it has started to malfunction. The two inner heating coils don't heat up or don't heat up enough to visibly glow. The odd things is that they do heat up when we select the "bagel" option. This seems like a weird combination of symptoms.
Anyhow,. thanks for the person who provided this teardown guide. Taking it apart and staring dumbly at the pieces was on my TODO list.
WJCarpenter - Yanıt
Hi everyone! Power surge burnt out the IC in mine so that the part number is unreadable. Can anyone tell me what the IC is?
Jesse Fox-Allen - Yanıt
There is no toaster I have used that is as good as this toaster. Have had mine for 6 years. Took it apart and fixed it myself 2 years ago. Worked perfectly until a few days ago. Not sure I can repair it this time. I will be buying another. Complex but well designed. Stands alone as far as I'm concerned.
John Phillips - Yanıt
Tried to unscrew the bottom of the toaster, but not a traditional Phillips SD fit (of any size). Is it a British thing? ;) Anyway, since couldn't unscrew bottom panel as advised, I made sure all crumbs were removed with a good shake and cleaned the drawer. . .when plugging in afterwards, it worked fine. It's a tempermental toaster, for sure, but this is the first time it didn't work for me in two years, and I have gone through plenty of toasters in the past (expensive and cheap) that haven't held up as well
Dana Casale - Yanıt
Our Breville toasting elements have failed. Are you saying I can't repair it?
Simon Pockley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 55
Son 30 gün: 227
Her zaman: 19,421
