Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Technicolor TC7200.U cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Technicolor TC7200.U Teardown, remove top cover: adım 1, 3 resimden 1. Technicolor TC7200.U Teardown, remove top cover: adım 1, 3 resimden 2. Technicolor TC7200.U Teardown, remove top cover: adım 1, 3 resimden 3.
    • Remove the 2 rubber feet covering up the screws holding the top cover.
    • Unscrew the T10 screws.
    • Use the spudger to pry open the top cover and remove it.
  2. Technicolor TC7200.U Teardown, remove board from case: adım 2, 2 resimden 1. Technicolor TC7200.U Teardown, remove board from case: adım 2, 2 resimden 2.
    • It this point, the board is held in place by the case itself.
    • Bend the front side of the case outward, allowing the board to move up.
    • With the front side removed from the case, slide the backside of the board from the case as well
  3. Technicolor TC7200.U Teardown, separate case from board: adım 3, 2 resimden 1. Technicolor TC7200.U Teardown, separate case from board: adım 3, 2 resimden 2.
    • Two parts are still attached to the case.
    • Use the spudger to separate the glued on part from the case and repeat on the other side.
  4. Technicolor TC7200.U Teardown, explore the board: adım 4, 3 resimden 1. Technicolor TC7200.U Teardown, explore the board: adım 4, 3 resimden 2. Technicolor TC7200.U Teardown, explore the board: adım 4, 3 resimden 3.
    • Remove the lid of the cable case.
    • View the board
    • Bothhand GS5014LF
    • STMicroelectronics NAND512W3A2CN6
    • Unscrew the WiFi module.
knipwim
13.397 İtibar
39 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 1,348
