Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Tesco Value JK07 Kettle cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Tesco Value JK07 Kettle Teardown, Tesco Value JK07 Kettle Teardown: adım 1, 2 resimden 1. Tesco Value JK07 Kettle Teardown, Tesco Value JK07 Kettle Teardown: adım 1, 2 resimden 2.
    • Remove the kettle from its base.
    • Remove the limescale filter by sliding it out from the lip.
  2. Tesco Value JK07 Kettle Teardown: adım 2, 3 resimden 1. Tesco Value JK07 Kettle Teardown: adım 2, 3 resimden 2. Tesco Value JK07 Kettle Teardown: adım 2, 3 resimden 3.
    • Remove the screw from the bottom side of the lid.
    • Disassemble the lid and remove the plastic piece inside.
  3. Tesco Value JK07 Kettle Teardown: adım 3, 1 resimden 1.
    • Remove the button that opens the lid by sliding it out.
  4. Tesco Value JK07 Kettle Teardown: adım 4, 2 resimden 1. Tesco Value JK07 Kettle Teardown: adım 4, 2 resimden 2.
    • Remove the screws on the underside of the kettle to release the socket cover.
    • Separate the handle from the kettle.
  5. Tesco Value JK07 Kettle Teardown: adım 5, 2 resimden 1. Tesco Value JK07 Kettle Teardown: adım 5, 2 resimden 2.
    • Remove the screws to separate the handle and the lid from the hinge.
  6. Tesco Value JK07 Kettle Teardown: adım 6, 3 resimden 1. Tesco Value JK07 Kettle Teardown: adım 6, 3 resimden 2. Tesco Value JK07 Kettle Teardown: adım 6, 3 resimden 3.
    • Gently remove the switch cover.
    • Remove the circular piece attached to the switch base by gently pulling it away.
  7. Tesco Value JK07 Kettle Teardown: adım 7, 2 resimden 1. Tesco Value JK07 Kettle Teardown: adım 7, 2 resimden 2.
    • Remove the screws from the socket at the back of the kettle.
    • These screws also hold the socket together, so once they have been removed, it can be opened.
    • The components within the socket are clipped in. Remove the components by gently pulling.
  8. Tesco Value JK07 Kettle Teardown: adım 8, 2 resimden 1. Tesco Value JK07 Kettle Teardown: adım 8, 2 resimden 2.
    • Remove the heating element.
    • Remove the gasket.
    • Remove the plate beneath the heating element by bending the metal in the holes as shown in the picture. Remove the plate from the clips.
  9. Tesco Value JK07 Kettle Teardown: adım 9, 1 resimden 1.
    • Remove all the screws from the bottom, then gently separate the two halves.
  10. Tesco Value JK07 Kettle Teardown: adım 10, 1 resimden 1.
    • Push the feet (B) out from the base (C).
  11. Tesco Value JK07 Kettle Teardown: adım 11, 1 resimden 1.
    • The plug and cable (G) are held in by clips and can be pulled away.
    • The fuse (F) can be pulled away from inside the pins on the plug (G).
  12. Tesco Value JK07 Kettle Teardown: adım 12, 1 resimden 1.
    • The kettle is now fully disassembled.
    • There should be 26 separate parts, all shown here in this photo.
emily king
21 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 7,140
