Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Texas Instruments TI BA II Plus cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Texas Instruments TI BA II Plus Teardown, Texas Instruments TI BA II Plus Teardown: adım 1, 1 resimden 1.
    • The BA II Plus Professional calculator.
  2. Texas Instruments TI BA II Plus Teardown: adım 2, 1 resimden 1.
    • Remove the battery cover by sliding it out.
  3. Texas Instruments TI BA II Plus Teardown: adım 3, 1 resimden 1.
    • Firstly on the back cover, remove the small sticky soft cushioning material covering the recess with the screws in it. 4 of them in total. Unscrew them.
  4. Texas Instruments TI BA II Plus Teardown: adım 4, 1 resimden 1.
    • Use a flathead screwdriver to gently part the bottom and top cover at the hinge on the top.
  5. Texas Instruments TI BA II Plus Teardown: adım 5, 1 resimden 1.
    • Removing the back cover to reveal the foil, unscrew the 4 screws holding the foil and 4 other holding the printed circuit board to the front cover.
  6. Texas Instruments TI BA II Plus Teardown: adım 6, 1 resimden 1.
    • Remove the foil. Ensure all screws are off.
  7. Texas Instruments TI BA II Plus Teardown: adım 7, 1 resimden 1.
    • This must separate the front cover from the board. Remove the board and turn it over to view the front side with a soft black cushion cover over a smooth shinny mesh.
  8. Texas Instruments TI BA II Plus Teardown: adım 8, 1 resimden 1.
    • The keys should fall out of the front cover when you turn it over as well. Thats it!!!
VSP
101 İtibar
1 Kılavuz yazıldı
4Kılavuz Yorumları
Well, my TI BA II plus has a broken LCD screen which according to the customer care is not covered under the warranty. Is it possible to find a replacement LCD to replace the broken one in the calculator.
Thanks
VSP - Yanıt
My calculated get in water, now its not working is there any way to repair it.
ankur - Yanıt
Did it stopped working immediately ? Also what did u do then
Akshat S Gupta -
This is a terrific service that you are providing. It makes fixing thing so much easier. Thank you.
ROB LYTLE - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 39
Her zaman: 9,596
