Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Texas Instruments TI-30 XS Multiview cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Texas Instruments TI-30 XS Multiview Teardown, Remove the back panel: adım 1, 3 resimden 1. Texas Instruments TI-30 XS Multiview Teardown, Remove the back panel: adım 1, 3 resimden 2. Texas Instruments TI-30 XS Multiview Teardown, Remove the back panel: adım 1, 3 resimden 3.
    • Using the Phillips head screwdriver, remove the 6 screws
    • Pry the back panel open with the flathead
  2. Texas Instruments TI-30 XS Multiview Teardown, Remove the battery: adım 2, 2 resimden 1. Texas Instruments TI-30 XS Multiview Teardown, Remove the battery: adım 2, 2 resimden 2.
    • Remove the two screws holding the battery down
    • Take off the metal cover
    • Remove the battery
  3. Texas Instruments TI-30 XS Multiview Teardown, Remove the LCD: adım 3, 3 resimden 1. Texas Instruments TI-30 XS Multiview Teardown, Remove the LCD: adım 3, 3 resimden 2. Texas Instruments TI-30 XS Multiview Teardown, Remove the LCD: adım 3, 3 resimden 3.
    • Use the Phillips head screwdriver to remove the two screws securing the LCD to the plastic chassis
    • With the flathead, wedge out the LCD screen without disconnecting the internal wiring
    • This is the furthest that the calculator can be torn down without destroying the calculator beyond repair
  4. Texas Instruments TI-30 XS Multiview Teardown, Reassmble the calculator: adım 4, 1 resimden 1.
    • Reassemble the calculator, placing the LCD screen, battery, back panel, and screws in the proper position
    • After the calculator is reassembled, the calculator truly works as it did before the teardown
Regita Soetandar
109 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,150
