Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Texas Instruments TI-82 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Texas Instruments TI-82 Teardown, Texas Instruments TI-82 Teardown: adım 1, 1 resimden 1.
    • The calculator comes with a matching protective shield which slides down over the front; when the calculator is in use, you can slide it over the back. This is a nice touch, as it makes the cover much more difficult to lose.
  2. Texas Instruments TI-82 Teardown: adım 2, 3 resimden 1. Texas Instruments TI-82 Teardown: adım 2, 3 resimden 2. Texas Instruments TI-82 Teardown: adım 2, 3 resimden 3.
    • Flip the device over to access the battery cover.
    • Using a spudger, pry the release tab down and then pull the battery door up and off the calculator.
    • Remove:
    • 2 7.2mm Phillips #0 screws
    • 1 15.3mm Phillips #0 screw, and a battery retaining clip.
    • The CR1616 coin cell battery preserves settings and programs in memory while the main batteries are being changed.
  3. Texas Instruments TI-82 Teardown: adım 3, 1 resimden 1.
    • Insert a spudger into the seam between the two halves of the case, and pry it apart.
    • Watch out for corrosion in older calculators around the battery terminals -- this is why you should never leave batteries in electronics for extended periods of time.
  4. Texas Instruments TI-82 Teardown: adım 4, 1 resimden 1.
    • Opening the two halves of the calculator reveals a foil shield over the rest of the electronics.
    • Remove four Phillips screws to access the electronics underneath, then pull the shield away.
  5. Texas Instruments TI-82 Teardown: adım 5, 1 resimden 1.
    • ... And, here's the guts of the thing.
    • SRM20255LLM10 / F4ZM1938 (32Kbyte SRAM)
    • LH531GP4 (Mask ROM)
    • T 84C00AM-8 (Z80 CPU)
    • Toshiba / TC14L010AF / 1273 9506EAI (ASIC)
  6. Texas Instruments TI-82 Teardown: adım 6, 2 resimden 1. Texas Instruments TI-82 Teardown: adım 6, 2 resimden 2.
    • Remove the remaining Phillips screws.
    • The screen and main board will lift out, leaving the membrane keypad in the front case.
bushing
10.250 İtibar
13 adet Kılavuz yazıldı
Bir Yorum
Minor correction, the RAM part is SRM20256LLM10, a CMOS 256 kilobit (32x8) 100ns static RAM in 28 pin SOP form factor.
Nick M - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 88
Her zaman: 20,595
