Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Texas Insturments TI-84 Plus Color Silver Edition cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: adım 1, 3 resimden 1. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: adım 1, 3 resimden 2. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: adım 1, 3 resimden 3.
    • Wisdom
  2. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: adım 2, 2 resimden 1. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: adım 2, 2 resimden 2.
    • Unplug the battery.
    • Be careful not to fray cable while unplugging.
  3. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: adım 3, 3 resimden 1. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: adım 3, 3 resimden 2. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: adım 3, 3 resimden 3.
    • Remove the back cover by removing the 6 Pentalobe screws (P6)
    • The front cover can be taken off by prying it off from the front of the device
    • Then pry off the back cover it can be a little challenging but take your time
  4. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: adım 4, 3 resimden 1. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: adım 4, 3 resimden 2. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: adım 4, 3 resimden 3.
    • Remove the 6 Philips screws holding the mother board and if you want remove the foil just to see the full board itself
    • To change out the buttons take out the grey rubber sheet that separates them from the board (be careful with the buttons as they will fall out)
ArabianBoi1259
103 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 452
