Bu Teardown'da Kullanılan Aletler
Giriş
We partnered with Wired to bring you a peek inside an FBI car-tracking device. The device is similar to the one Yasir Afifi found underneath his car. If you're curious where this one came from, Wired has posted a writeup about Kathy Thomas, the woman who found this tracker under her car. They've also posted a video of Kyle doing the teardown.
The device comprises a GPS unit for receiving the car's position, an RF transmitter for relaying your location to the interested authority (i.e., the FBI), and a set of sweet D-cell batteries that power the whole enchilada. But we didn't stop there, of course. Read on to find out exactly what components make this secretive device tick.
Disclaimer: We love the FBI. We've worked with them on several occasions to fight crime and locate criminals. We've helped them with instructions on gaining entry into certain devices. We have nothing against them, and we hope they don't come after us for publishing this teardown.
We finally have one of these on the teardown table! Being in its presence, we can almost feel our civil liberties being flushed down the toilet.
Before we whip out the blowtorches and jackhammers, here's a look at the entire tracking system.
Clockwise from the top, the system consists of:
Battery pack
GPS antenna
Transmitter/receiver unit
Magnetic mounting bracket
Wondering what kind of technology keeps the tracking device powered? Let's remove the battery pack's end cap and find out.
The device is powered by four lithium-thionyl chloride (Li-SOCl2) D cell batteries.
Each cell is good for 13,000 mAh! That's about double the capacity of the iPad 2's battery.
To begin tearing the device apart, we detached the two antennas from their screw-in mounts on the transmitter/receiver module.
The short antenna we disconnected in the first picture is responsible for transmitting the location signal to transponders that the FBI would use to find you.
The larger antenna is for receiving GPS signals from satellites orbiting far above the earth's surface.
Removing a few Phillips screws allows us to access the innards of the GPS antenna.
In keeping with the non-permanent mounting solutions, the GPS antenna is attached to its bracket with a hefty piece of Velcro.
A quick peek at the antenna board indicates it was manufactured by SIgem, a company that partnered with Tyco in the early 2000s to make GPS components.
Let's turn our attention back to the transmitter/receiver module.
A few screws are all that remain between us and the innards of this invasive device.
It seems that this rear cover is simply a method to connect the module to power. Presumably, power sources (batteries) of different shapes/sizes/capacities can be connected through the same plate to make the tracking device more universally installable.
The module providing the GPS signal processing on this device is a µ-blox GPS-MS1 that's sort of ancient in the realm of modern electronics.
It was released June 29, 1999!
It features an astonishing 0.125 MB of SRAM and 1 MB of flash memory.
The backup battery on its reverse side powers a real time clock and maintains the GPS receiver's SRAM to allow for a much faster connection time to the satellites, called a warm start. This is usually used in conjunction with a circuit to power down most of the GPS, providing a much longer battery life.
The larger of the two boards contains the connections for both antennas and is responsible for the RF side of the tracking device. Its notable chips include:
XEMICS XE1201 Ultra low power single chip transceiver
The XE1201 allows for data transmission and data reception in half duplex mode.
RFM RF1172 SAW (surface-acoustic-wave) filter
The RF1172 provides front-end selectivity (the capability to separate signals in one frequency from all other frequencies) in 433.92 MHz receivers.
Typical applications of this filter include wireless remote-control and security devices operating in Europe under ETSI I-ETS 300 220.
Tracking device Repairability Score: -10 out of 10 (10 is easiest to repair)
The FBI will find you if you find their tracking device.
You cannot choose to be not tracked by the FBI.
You can legally be tracked by one of these units.
We'll be right back, the FBI is knocking on our door.
If you think this sort of thing is super cool, we'd like you to join our team. We're hiring software engineers and designers to help us make our how-to community even more awesome.
iFixit is a great place to work. We have an incredible working environment, a world-class team, and a vision to change the world. Our team loves having fun together. Developers have private offices, we have regular barbecues, and we're based in San Luis Obispo, one of the most amazing places in the world.
Open positions:
By the way, that last photo looks like a postcard—but we took it just down the street from our office two weeks ago. (Some HDR may have been involved. Yes, we're photo geeks.)
14 Yorum
The "backup battery" on the back of the GPS module looks to me like a super-capacitor. These are usually used on GPS's to maintain the contents of the SRAM when the unit is powered down. Maintaining the SRAM means that the GPS gets a lock much faster (See GPS warm-start) when powered back up again. This combined with a power gating circuit will mean that the device can last much longer.
It's actually a Panasonic VL1220 lithium battery.
That might be an ancient GPS but if I'm not mistaken, the FBI will have access to 100% accurate GPS signals (rather than the - within 300 metres that we lowly mortals get) so that's one handy piece of kit...
That'd be cool, but selective availability (the 300' civilian accuracy limit) was turned off more than 10 years ago. This thing's gps is probably not any more accurate than your typical smart phone.
