Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Ubee DVW23C cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Ubee DVW23C Teardown, Ubee DVW23C Teardown: adım 1, 3 resimden 1. Ubee DVW23C Teardown, Ubee DVW23C Teardown: adım 1, 3 resimden 2. Ubee DVW23C Teardown, Ubee DVW23C Teardown: adım 1, 3 resimden 3.
    • As we look around the device, the only visible screws are 4 on the back, and one by the power connector.
    • All the screws so far are T10 Torx.
  2. Ubee DVW23C Teardown: adım 2, 2 resimden 1. Ubee DVW23C Teardown: adım 2, 2 resimden 2.
    • Prying away the front panel reveals the inside.
  3. Ubee DVW23C Teardown: adım 3, 2 resimden 1. Ubee DVW23C Teardown: adım 3, 2 resimden 2.
    • The PSU is red
    • The Broadcom chip is orange.
    • The DOCSIS Cable connector is yellow
    • The PSU Connector is green
    • The Antenna connectors are blue
    • The lights and diffusers are light blue
    • The ethernet and telephone jacks are magenta
  4. Ubee DVW23C Teardown: adım 4, 2 resimden 1. Ubee DVW23C Teardown: adım 4, 2 resimden 2.
    • The PSU comes out with one screw, and the power connector screw.
    • It is the N12-035N1A Power Supply from Chicony Power.
  5. Ubee DVW23C Teardown: adım 5, 2 resimden 1. Ubee DVW23C Teardown: adım 5, 2 resimden 2.
    • Finally, removing the motherboard shows what it looks like on the back.
  6. Ubee DVW23C Teardown, Conclusion: adım 6, 3 resimden 1. Ubee DVW23C Teardown, Conclusion: adım 6, 3 resimden 2. Ubee DVW23C Teardown, Conclusion: adım 6, 3 resimden 3.
    • In conclusion, this is one of the more repairable modem/router combos, especially since it's from an ISP.
    • All the screws are the same, and while the T10 isn't user-friendly, it's easy to find online and in stores, and having a unified screw simplifies the repair process.
    • The PSU is completely easily replaceable, but is unfortunately custom made for this model, and not found online.
    • So while it's easy to open, it isn't easy to find replacement parts.
    • Backups are also downloaded unencrypted, unfortunately, and with no way to update the firmware, it won't get fixed. The backups contain both your password, and the technician password (Username: technician / Password: C0nf1gur3Ubee#) inside the file.
9021007
4.562 İtibar
25 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 1,076
