Ana içeriğe geç
Velleman DVM850BL Digital Multimeter Teardown
Neye ihtiyacın var
  1. Velleman DVM850BL Digital Multimeter Teardown, Removing Leads: adım 1, 1 resimden 1.
    • Remove lead connectors from front panel.
  2. Velleman DVM850BL Digital Multimeter Teardown, Remove Back Casing Screws: adım 2, 3 resimden 1. Velleman DVM850BL Digital Multimeter Teardown, Remove Back Casing Screws: adım 2, 3 resimden 2. Velleman DVM850BL Digital Multimeter Teardown, Remove Back Casing Screws: adım 2, 3 resimden 3.
    • Turn over the DVM and unscrew the two screws using a J1 bit.
  3. Velleman DVM850BL Digital Multimeter Teardown, Battery and PCB Screw Removal: adım 3, 3 resimden 1. Velleman DVM850BL Digital Multimeter Teardown, Battery and PCB Screw Removal: adım 3, 3 resimden 2. Velleman DVM850BL Digital Multimeter Teardown, Battery and PCB Screw Removal: adım 3, 3 resimden 3.
    • Remove battery by gently disconnecting it from connector.
    • Remove three screws using J1 bit.
  4. Velleman DVM850BL Digital Multimeter Teardown, PCB Removal: adım 4, 2 resimden 1. Velleman DVM850BL Digital Multimeter Teardown, PCB Removal: adım 4, 2 resimden 2.
    • Remove PCB by gently pulling it away from the back encasing.
    • Microprocessor
    • Continuity Check Speaker
    • Fuse
    • 9 V Battery Connector
  5. Velleman DVM850BL Digital Multimeter Teardown, Complete The Teardown: adım 5, 3 resimden 1. Velleman DVM850BL Digital Multimeter Teardown, Complete The Teardown: adım 5, 3 resimden 2. Velleman DVM850BL Digital Multimeter Teardown, Complete The Teardown: adım 5, 3 resimden 3.
    • Remove the knob and buttons from the front grey casing.
    • The measurement knob uses two ball bearings that allows the knob to rotate. These bearings are small and easy to lose.
    • Backlight Toggle Button
    • Measurement Hold Button
    • LCD Plastic Cover
    • Measurement Select Knob
    • Measurement Select Knob Ball Bearings
    • Success! You have finished tearing down the multimeter.
Bitiş Çizgisi
Michael
365 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G32
4 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Don't take the contacts out of the rotary dial. It's very easy to forget where they go
Oliver Watson - Yanıt
This web page seems very helpful. However is it necessary to remove the micro processor or front knobs and buttons if all is working fine? What meter do you use to check the fuse? This one when the battery is changed? LOL And why does the print and photos change size when I try to scroll down the page after I reset it to 100 % ? Am I using Windows 10 wrong? Thanks
jaystuarthenderson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 2,486
