Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Fan cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Vornado Zippi Fan Teardown, Removing Stand: adım 1, 3 resimden 1. Vornado Zippi Fan Teardown, Removing Stand: adım 1, 3 resimden 2. Vornado Zippi Fan Teardown, Removing Stand: adım 1, 3 resimden 3.
    • Pull the stand out of the enclosure on each side
  2. Vornado Zippi Fan Teardown, Remove Blades and Speed Control: adım 2, 3 resimden 1. Vornado Zippi Fan Teardown, Remove Blades and Speed Control: adım 2, 3 resimden 2. Vornado Zippi Fan Teardown, Remove Blades and Speed Control: adım 2, 3 resimden 3.
    • Remove the blades by pulling away from the enclosure
    • Remove the speed control by pulling away from the enclosure
  3. Vornado Zippi Fan Teardown, Remove Guard Screws: adım 3, 2 resimden 1. Vornado Zippi Fan Teardown, Remove Guard Screws: adım 3, 2 resimden 2.
    • Remove the 4 screws coupling the orange plastic enclosure and black plastic guard
  4. Vornado Zippi Fan Teardown, Remove Enclosure Screws: adım 4, 3 resimden 1. Vornado Zippi Fan Teardown, Remove Enclosure Screws: adım 4, 3 resimden 2. Vornado Zippi Fan Teardown, Remove Enclosure Screws: adım 4, 3 resimden 3.
    • Remove the screw coupling the top half of the enclosure
    • Remove the screw coupling the bottom of the enclosure, near the power cable
    • Remove the screw beneath the rubber inserts holding the stand
  5. Vornado Zippi Fan Teardown, Remove Enclosure and Guard: adım 5, 3 resimden 1. Vornado Zippi Fan Teardown, Remove Enclosure and Guard: adım 5, 3 resimden 2. Vornado Zippi Fan Teardown, Remove Enclosure and Guard: adım 5, 3 resimden 3.
    • Separate the two halves of the enclosure, leaving the power cable, switch, motor and guard
    • Remove the 2 screws attaching the guard to the motor
  6. Vornado Zippi Fan Teardown, Remove Switch: adım 6, 2 resimden 1. Vornado Zippi Fan Teardown, Remove Switch: adım 6, 2 resimden 2.
    • Remove the 2 screws holding the switch in the mount connected to the motor
  7. Vornado Zippi Fan Teardown, Remove Switch Mount: adım 7, 2 resimden 1. Vornado Zippi Fan Teardown, Remove Switch Mount: adım 7, 2 resimden 2.
    • Remove the two screws securing the switch mount to the motor
Nathan Lentz
20 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
Mine was making noise and difficult to get the nose cone pulled off. I used two coins in the crack on opposing sides and twisted them.
S Lewis - Yanıt
it won't keep it`s position ,folds and flaps out ,if i could tighten the arm
andre b - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,180
