Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. WD blue Hard Drive cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. WD Blue Hard Drive Teardown, Exterior of Hard drive: adım 1, 3 resimden 1. WD Blue Hard Drive Teardown, Exterior of Hard drive: adım 1, 3 resimden 2. WD Blue Hard Drive Teardown, Exterior of Hard drive: adım 1, 3 resimden 3.
    • Pre-disassembly
  2. WD Blue Hard Drive Teardown, Remove circuit board: adım 2, 2 resimden 1. WD Blue Hard Drive Teardown, Remove circuit board: adım 2, 2 resimden 2.
    • Remove four screws and circuit board lifts out
    What screwdriver tip fits the screws?
    Jim Fogle - Yanıt
  3. WD Blue Hard Drive Teardown, Circuit board interfaces: adım 3, 1 resimden 1.
    • Motor contacts
    • Head contacts
    Excellent. Love the highlights. They help a lot.
    Jim Fogle - Yanıt
  4. WD Blue Hard Drive Teardown, Removing top cover: adım 4, 3 resimden 1. WD Blue Hard Drive Teardown, Removing top cover: adım 4, 3 resimden 2. WD Blue Hard Drive Teardown, Removing top cover: adım 4, 3 resimden 3.
    • Remove 6 perimeter screws
    • Remove screw from under sticker
    • Lift cover off
    Maybe rotate 1st photo 180 degrees so the orientation matches photo 2. Also in photo 1 highlight the location of the hidden screw.
    Jim Fogle - Yanıt
  5. WD Blue Hard Drive Teardown, Inside details: adım 5, 3 resimden 1. WD Blue Hard Drive Teardown, Inside details: adım 5, 3 resimden 2. WD Blue Hard Drive Teardown, Inside details: adım 5, 3 resimden 3.
    • Inside of hard drive
    • Desiccant packet removed from lower right corner
    • Inside of cover
  6. WD Blue Hard Drive Teardown, Head details and dock removal: adım 6, 3 resimden 1. WD Blue Hard Drive Teardown, Head details and dock removal: adım 6, 3 resimden 2. WD Blue Hard Drive Teardown, Head details and dock removal: adım 6, 3 resimden 3.
    • Head in dock
    • Head on disk
    • Dock removed
    What size driver tip is used to remove the screw?
    Jim Fogle - Yanıt
  7. WD Blue Hard Drive Teardown, Head removal p1: adım 7, 3 resimden 1. WD Blue Hard Drive Teardown, Head removal p1: adım 7, 3 resimden 2. WD Blue Hard Drive Teardown, Head removal p1: adım 7, 3 resimden 3.
    • Head before bridge removed
    • Remove two screws
    • Lift bridge away
    Highlight screw location in photo 1. Provide driver tip used to remove screws.
    Jim Fogle - Yanıt
  8. WD Blue Hard Drive Teardown, Head travel limits: adım 8, 2 resimden 1. WD Blue Hard Drive Teardown, Head travel limits: adım 8, 2 resimden 2.
    • Stops to limit head travel
    • Red coil over magnet cause the head to rotate
  9. WD Blue Hard Drive Teardown, Head contact removal: adım 9, 2 resimden 1. WD Blue Hard Drive Teardown, Head contact removal: adım 9, 2 resimden 2.
    • Contact block installed
    • Remove two screws, contact block is now loose but connected to head by a ribbon cable
    Add driver tip size. Highlight ribbon cable as it blends in with body.
    Jim Fogle - Yanıt
  10. WD Blue Hard Drive Teardown, Disk removal p1: adım 10, 3 resimden 1. WD Blue Hard Drive Teardown, Disk removal p1: adım 10, 3 resimden 2. WD Blue Hard Drive Teardown, Disk removal p1: adım 10, 3 resimden 3.
    • Disk installed
    • Remove 3 screws holding down collar
    • Remove collar
    Highlight the screw faces please. The screw faces blend in with the collar.
    Jim Fogle - Yanıt
  11. WD Blue Hard Drive Teardown, Disk removal p2: adım 11, 2 resimden 1. WD Blue Hard Drive Teardown, Disk removal p2: adım 11, 2 resimden 2.
    • Lift disk out of case
    • Collar after removal
  12. WD Blue Hard Drive Teardown, Head removal p2: adım 12, 3 resimden 1. WD Blue Hard Drive Teardown, Head removal p2: adım 12, 3 resimden 2. WD Blue Hard Drive Teardown, Head removal p2: adım 12, 3 resimden 3.
    • Head installed, simply lift head out of case
    • Remove head
    • Case without head
    May want to identify the platter motor in photo 3
    Jim Fogle - Yanıt
  13. WD Blue Hard Drive Teardown, Head details: adım 13, 3 resimden 1. WD Blue Hard Drive Teardown, Head details: adım 13, 3 resimden 2. WD Blue Hard Drive Teardown, Head details: adım 13, 3 resimden 3.
    • Removed head
    • Contacts for data and head control
    • Head interface to disk
    Photo 3 is a great photo. Well done!
    Jim Fogle - Yanıt
  14. WD Blue Hard Drive Teardown, Empty case: adım 14, 2 resimden 1. WD Blue Hard Drive Teardown, Empty case: adım 14, 2 resimden 2.
    • Remove magnet
    • Remove stop for head on disk
    • Remove head docked stop
    What is the purpose of the black strip below where the head use to be?
    Jim Fogle - Yanıt
  15. WD Blue Hard Drive Teardown, Components laid out: adım 15, 3 resimden 1. WD Blue Hard Drive Teardown, Components laid out: adım 15, 3 resimden 2. WD Blue Hard Drive Teardown, Components laid out: adım 15, 3 resimden 3.
    • All components arranged
Wieli
2.141 İtibar
13 adet Kılavuz yazıldı
1Rehber Yorum
Well done Wieli! Your photographs are very clear and well lighted. Should you decide to edit the guide may I suggest (1) you add what screwdriver tips you used to remove screws and (2) at step 10, highlight the three screws. The screw tips blend in with the collar.
Jim Fogle - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 43
Son 30 gün: 234
Her zaman: 5,749
