Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Wahl Cordless Beard Trimmer cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Wahl Cordless Beard Trimmer Teardown, Remove battery cover: adım 1, 2 resimden 1. Wahl Cordless Beard Trimmer Teardown, Remove battery cover: adım 1, 2 resimden 2.
    • Begin by removing the battery cover from the back of the trimmer.
  2. Wahl Cordless Beard Trimmer Teardown, Remove battery: adım 2, 2 resimden 1. Wahl Cordless Beard Trimmer Teardown, Remove battery: adım 2, 2 resimden 2.
    • Remove the battery.
  3. Wahl Cordless Beard Trimmer Teardown, Remove metal blade: adım 3, 3 resimden 1. Wahl Cordless Beard Trimmer Teardown, Remove metal blade: adım 3, 3 resimden 2. Wahl Cordless Beard Trimmer Teardown, Remove metal blade: adım 3, 3 resimden 3.
    • Remove the screws, then gently lift off the blade. A small piece of plastic should come off with the blade. There will be a spring revealed from under the blade, remove this as well.
  4. Wahl Cordless Beard Trimmer Teardown, Separate plastic cover: adım 4, 2 resimden 1. Wahl Cordless Beard Trimmer Teardown, Separate plastic cover: adım 4, 2 resimden 2.
    • Remove the screws from the sides of the battery compartment. Then, gently separate the two halves of the plastic cover.
  5. Wahl Cordless Beard Trimmer Teardown, Remove switch: adım 5, 2 resimden 1. Wahl Cordless Beard Trimmer Teardown, Remove switch: adım 5, 2 resimden 2.
    • Lay both halves of the trimmer out, and remove the switch from the inside of the white plastic cover.
  6. Wahl Cordless Beard Trimmer Teardown, Remove motor: adım 6, 2 resimden 1. Wahl Cordless Beard Trimmer Teardown, Remove motor: adım 6, 2 resimden 2.
    • Finally, remove the motor from the black plastic cover. If desired, this motor can be de-soldered from the red wire and re-purposed.
arielletc28
167 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 53
Son 30 gün: 249
Her zaman: 14,827
