Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Western Digital My Book Live cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Western Digital My Book Live Teardown, Introduction: adım 1, 1 resimden 1.
    • The 2TB MyBook Live is an interesting desktop NAS, as it packs not only a 2TB HDD but also Debian Lenny on some peculiar hardware:
    • A WD Caviar Green 2TB desktop hard drive with 64MB cache, using "IntelliPower" technology
    • 256MB RAM
    • A PowerPC-based APM82181 CPU running at 800Mhz, single core, with built-in RAID acceleration
    • One multi-color LED in the front
    • Gigabit Ethernet
    • Debian Lenny for PowerPC
  2. Western Digital My Book Live Teardown, Removing the Cover: adım 2, 1 resimden 1.
    • While the MyBook Live's book-shaped chassis is nice, the clips preventing it from opening are not.
    • There are four inner clips in the back, 2 on each side of the chassis.
    • Slowly work around the clips, while opening the back, otherwise you risk breaking these. If you do, it's not too much of an issue.
    • Luckily, a Plastic Opening Tool can be used to separate the clips from the outer cover.
    • Simply insert the tool into the seams near the clip areas, and slowly pry the cover apart.
    • You may need to use multiple spudgers or screwdrivers to help separate the cover from the inner chassis.
    • Be careful and don't let any of the tools slide inside the chassis.
  3. Western Digital My Book Live Teardown, Sliding the Cover: adım 3, 2 resimden 1. Western Digital My Book Live Teardown, Sliding the Cover: adım 3, 2 resimden 2.
    • The cover slides off once the back clips are pried apart, which makes it easier to grab a hold of the cover.
    • The top and bottom rails of the cover snap off from the inner chassis as you push forward.
  4. Western Digital My Book Live Teardown, Front LED.: adım 4, 2 resimden 1. Western Digital My Book Live Teardown, Front LED.: adım 4, 2 resimden 2.
    • We remove the small plastic LED extension from the front of the unit.
    • It seems that the actual LED is on the CPU board, and WD used a small piece of plastic to bring the light over to the front of the unit.
  5. Western Digital My Book Live Teardown, Main Chassis: adım 5, 2 resimden 1. Western Digital My Book Live Teardown, Main Chassis: adım 5, 2 resimden 2.
    • Some rubber padding keeps the hard disk in place, but a little push allows us to separate the hardware from the inner chassis.
    • When reassembling, do not force the rubber padding back in if it does not fit, most often that means that you did not align the assembly properly.
  6. Western Digital My Book Live Teardown, Continued Removal: adım 6, 2 resimden 1. Western Digital My Book Live Teardown, Continued Removal: adım 6, 2 resimden 2.
    • Don't pull too fast! Some clips get in the way of the board, and you have to clear them by bending the outer frame slightly outwards.
    • We make sure that the board doesn't snag against the chassis.
  7. Western Digital My Book Live Teardown, Removing the Padding: adım 7, 2 resimden 1. Western Digital My Book Live Teardown, Removing the Padding: adım 7, 2 resimden 2.
    • There is a large padding block on the corner of the chassis.
    • We simply pull on it to remove it, the adhesive is non-residual.
  8. Western Digital My Book Live Teardown, Continued Removal: adım 8, 1 resimden 1.
    • As you push the chassis away from the board, you may also have to push on the corner area to push the metal tab away from its rubber socket.
  9. Western Digital My Book Live Teardown, Extracting the Board: adım 9, 2 resimden 1. Western Digital My Book Live Teardown, Extracting the Board: adım 9, 2 resimden 2.
    • Pushing upwards slightly eventually gets the board to release itself from the rubber pads.
    • We now have access to the board, completely freed from the main chassis.
  10. Western Digital My Book Live Teardown, Pulling the Rubber Feet: adım 10, 2 resimden 1. Western Digital My Book Live Teardown, Pulling the Rubber Feet: adım 10, 2 resimden 2.
    • Some rubber feet cover the other two metal tabs, we remove it by pulling on them.
  11. Western Digital My Book Live Teardown, Removing the Metal Tabs: adım 11, 2 resimden 1. Western Digital My Book Live Teardown, Removing the Metal Tabs: adım 11, 2 resimden 2.
    • Next we remove the 4 metal tabs (and their bars) by unscrewing the fasteners that hold them.
    • There are 4 screws, two on each side of the hard disk area.
  12. Western Digital My Book Live Teardown, Removing the Hard Drive shield: adım 12, 2 resimden 1. Western Digital My Book Live Teardown, Removing the Hard Drive shield: adım 12, 2 resimden 2.
    • After removing the metal clips and bars, we can now remove the shield covering the Hard Disk.
Foxlet
601 İtibar
3 adet Kılavuz yazıldı
10 Yorum
You do not break the rear 4 clips, simply insert an opening tool into the front (top side and bottom side) and slowly "walk it" open as you see being done in step #3.
Repeat, you do NOT need to break anything when you open up any device, if you think something is snapping, bending, or breaking, Stop and look for what you are missing with said repair.
as in this tear down, it should be completely silent, no popping of clips or rails.
Nick - Yanıt
Thanks for that advise and it's been very simple with the 4 clips.
patrickkluge -
I find it unfortunate you didn't showed what kind of harddrive the WDMybookLive contains.
Sander Schaeffer - Yanıt
Maybe it’s a little bit too late now, but it is a WD Red NAS drive
Andres Rendon -
Totally brilliant. Much easier to follow than the videos i watched on UnoWhat!
Christopher Lambert - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 52
Son 30 gün: 184
Her zaman: 34,615
