Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Wii Balance Board cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Wii Balance Board Teardown, Wii Balance Board Teardown: adım 1, 3 resimden 1. Wii Balance Board Teardown, Wii Balance Board Teardown: adım 1, 3 resimden 2. Wii Balance Board Teardown, Wii Balance Board Teardown: adım 1, 3 resimden 3.
    • First remove the circles from the balance board. The circles are in the corners.
    • Unscrew the 4 circles first then unscrew the middle screws that secure the base.
    • Remove the circles and the base.
    • Don't pull off the big chip or the motherboard, just unscrew the middle so it won't break.
  2. Wii Balance Board Teardown: adım 2, 2 resimden 1. Wii Balance Board Teardown: adım 2, 2 resimden 2.
    • If you want to take off the motherboard first you have to unscrew the screw in the middle then you can take it off.
  3. Wii Balance Board Teardown: adım 3, 1 resimden 1.
    • Then when you're done, screw back the motherboard in the same place where it was.
  4. Wii Balance Board Teardown: adım 4, 1 resimden 1.
    • When you're done screwing the motherboard in, screw back the middle piece first so you can put it back together.
  5. Wii Balance Board Teardown: adım 5, 1 resimden 1.
    • The last step is to screw in the corners and the circles, and then you will be done.
efraim
117 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 79
Her zaman: 6,439
