Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Withings Body Cardio cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Withings Body Cardio Teardown, Opening the scale: adım 1, 3 resimden 1. Withings Body Cardio Teardown, Opening the scale: adım 1, 3 resimden 2. Withings Body Cardio Teardown, Opening the scale: adım 1, 3 resimden 3.
    • Opening up the scale was not an easy task – there was a lot of double-sided tape involved.
    • The back of the scale is fastened with four Torx screws – easy enough. The entire backplate, however, is glued to the front with double-sided adhesive cushions. Removing it simply involved pulling it firmly enough to break the adhesive, but not so hard as to break the connectors. A hairdryer can help loosen the adhesive under the 4 corners.
    • With the backplate removed, you can immediately spot 4 loads cells, one in each corner.
  2. Withings Body Cardio Teardown, Main PCB: adım 2, 3 resimden 1. Withings Body Cardio Teardown, Main PCB: adım 2, 3 resimden 2. Withings Body Cardio Teardown, Main PCB: adım 2, 3 resimden 3.
    • ARM MCU - MK22FN1M0VLL12 (NXP)
    • weighing scale and body composition front-end IC - AFE4300 (Texas Instruments)
    • battery charging IC (including battery protection) - BQ24095 (Texas Instruments)
    • WiFi and Bluetooth radio - BCM43438 (Broadcom)
    • flash memory - MX25L3233F (Macronix)
    • op-amp - AD8544
    • connector to the USB port PCB
  3. Withings Body Cardio Teardown, Block diagram: adım 3, 1 resimden 1.
    • I’ve made an attempt to design a block diagram for the whole setup. This won’t be 100% accurate as I don’t know all the details but it will give you an idea on how the components are interlinked and work together.
November Five
465 İtibar
4 adet Kılavuz yazıldı
38 Yorum
Thanks for sharing your experience, wouldn’t guess the double sided tape trick without your help.
Soon my scale will be deactivated by Nokia and was wondering what I can do with it.
ALMO - Yanıt
Hi please tell me what are battery dimensions. I need to order one - cause mine is already dead.
Michal - Yanıt
Hi, I never took note of the dimensions, it’s best you open up the scale yourself to check it out.
Since the battery is dead you’ll have to do it anyways ;)
November Five -
Thanks for the breakdown info. I'm replacing the battery as well. It's 63x50x5mm. 2100 mAh, 7.98Wh, 3.8V
I think this battery should be exactly the same:
Samsung 2100 mAh Replacement Battery for Samsung Galaxy Avant SM-G386T https://www.amazon.com/dp/B00OY9BY6W/ref...
Ryan Wills - Yanıt
Hi,
my battery died as well. Was the Samsung battery the correct replacement?
With best regards
MArtin
spamfilter -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 39
Son 30 gün: 230
Her zaman: 23,954
