Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Xbox 360 Wireless Controller cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Xbox 360 Wireless Controller Teardown, Introduction: adım 1, 1 resimden 1.
    • Remove 7 screws located on the back of the controller using the TR-9 Toolbit
  2. Xbox 360 Wireless Controller Teardown, Removing Analog Sticks: adım 2, 3 resimden 1. Xbox 360 Wireless Controller Teardown, Removing Analog Sticks: adım 2, 3 resimden 2. Xbox 360 Wireless Controller Teardown, Removing Analog Sticks: adım 2, 3 resimden 3.
    • Then take off and replace the analog sticks if they arent functioning correctly.
  3. Xbox 360 Wireless Controller Teardown, Removing D-Pad: adım 3, 1 resimden 1.
    • Remove two screws from the D-Pad using a Phillips #0 Screwdriver, After doing so, you will see two latches underneath the screws that you just removed and you have to press the two latches at the same time to completely remove the D-Pad.
  4. Xbox 360 Wireless Controller Teardown, All of the Xbox 360 controller parts: adım 4, 2 resimden 1. Xbox 360 Wireless Controller Teardown, All of the Xbox 360 controller parts: adım 4, 2 resimden 2.
    • If you followed these directions successfully this is what the final result should look like.
  5. Xbox 360 Wireless Controller Teardown: adım 5, 1 resimden 1.
    • Full IC Identification:
    • You may need to enlarge it to view the text.
RareWarrior123
119 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
man this taredown is terrable . tr9 not t3 from the start .. .. man should just take it down and try again
Dub Lux - Yanıt
That is an awful description of how to tear down this controller.
Nicholas Bennett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 172
Her zaman: 12,229
