Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Xbox One Wireless Controller Model 1537 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Xbox One Wireless Controller Teardown, Get an Xbox One Controller: adım 1, 1 resimden 1.
    • Start off with having an Xbox One Controller (:
  2. Xbox One Wireless Controller Teardown, Remove First Screw: adım 2, 2 resimden 1. Xbox One Wireless Controller Teardown, Remove First Screw: adım 2, 2 resimden 2.
    • Start with removing the battery pack and exposing the T8 security screw. The screw should be hidden behind a warranty sticker.
  3. Xbox One Wireless Controller Teardown, Remove side panels: adım 3, 3 resimden 1. Xbox One Wireless Controller Teardown, Remove side panels: adım 3, 3 resimden 2. Xbox One Wireless Controller Teardown, Remove side panels: adım 3, 3 resimden 3.
    • Remove the side panels exposing the second T8 security screw using a spudger, an IFixit Opening Tool, or your nails, each choice is fun.
  4. Xbox One Wireless Controller Teardown, Remove all screws: adım 4, 1 resimden 1.
    • By removing all side panels all 5 T8 security screws have appeared!
  5. Xbox One Wireless Controller Teardown, Remove Faceplate: adım 5, 3 resimden 1. Xbox One Wireless Controller Teardown, Remove Faceplate: adım 5, 3 resimden 2. Xbox One Wireless Controller Teardown, Remove Faceplate: adım 5, 3 resimden 3.
    • Once you removed the T8 security screws remove the front face plate.
  6. Xbox One Wireless Controller Teardown, Tape down rumble motors: adım 6, 2 resimden 1. Xbox One Wireless Controller Teardown, Tape down rumble motors: adım 6, 2 resimden 2.
    • Tape down the rumbler motors to prevent them from falling out.
  7. Xbox One Wireless Controller Teardown, Remove T6 screws: adım 7, 3 resimden 1. Xbox One Wireless Controller Teardown, Remove T6 screws: adım 7, 3 resimden 2. Xbox One Wireless Controller Teardown, Remove T6 screws: adım 7, 3 resimden 3.
    • Remove the T6 screws to remove the PCB's.
    • It takes a pull to seperate the connectors.
    • Watch the wires! You can not fully remove the circuit board without removing the wires and it requires soldering.
  8. Xbox One Wireless Controller Teardown: adım 8, 3 resimden 1. Xbox One Wireless Controller Teardown: adım 8, 3 resimden 2. Xbox One Wireless Controller Teardown: adım 8, 3 resimden 3.
    • Remove the top cover, it folds over.
    • There are 6 T6 screws to remove.
  9. Xbox One Wireless Controller Teardown: adım 9, 3 resimden 1. Xbox One Wireless Controller Teardown: adım 9, 3 resimden 2. Xbox One Wireless Controller Teardown: adım 9, 3 resimden 3.
    • Remove the circuit board
    • Under the rubber is the A B X Y buttons.
  10. Xbox One Wireless Controller Teardown: adım 10, 3 resimden 1. Xbox One Wireless Controller Teardown: adım 10, 3 resimden 2. Xbox One Wireless Controller Teardown: adım 10, 3 resimden 3.
    • Follow the instructions in reverse to get everything together again. :D
ubaldo gutierrez
262 İtibar
1 Kılavuz yazıldı
15 Yorum
Very good instructions...
Chadwick Posey - Yanıt
Nice instructions. I need to take apart mine and replace the d-pad. The previous owner was a bit... rough. Sometimes it doesn't work or it clicks twice. Cheers!
Johnathan - Yanıt
Do you think that you can label the internals of the controller.
David Becerra - Yanıt
I have a custom controller from the xbox design labs. I want to change the led on the front.
Can someone point out the model/ size led I would need?
Alajandro - Yanıt
How do you put the sync buttom back in? Which way does it face?
Throaty Sea5 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 38
Son 7 gün: 290
Son 30 gün: 1,339
Her zaman: 168,625
