Ana içeriğe geç
Bu söküm üzerinde çalışılıyor – Son değişiklikleri görmek için düzenli olarak yenile!
  1. First you need to remove 6 screws using a T 20 screwdriver. Two are hidden in 2 stickers. First you need to remove 6 screws using a T 20 screwdriver. Two are hidden in 2 stickers. First you need to remove 6 screws using a T 20 screwdriver. Two are hidden in 2 stickers.
    • First you need to remove 6 screws using a T 20 screwdriver. Two are hidden in 2 stickers.
  2. Lift the top part of the Xbox. It can be hard.
    • Lift the top part of the Xbox. It can be hard.
  3. Now you need to remove 2 cords. The power cord can be tricky. Remove 1 screw using a T 10 screwdriver. Now you need to remove 2 cords. The power cord can be tricky. Remove 1 screw using a T 10 screwdriver. Now you need to remove 2 cords. The power cord can be tricky. Remove 1 screw using a T 10 screwdriver.
    • Now you need to remove 2 cords. The power cord can be tricky. Remove 1 screw using a T 10 screwdriver.
  4. You should lift the hard drive. Remove 2 cords and remove 2 screws. You’ve made it to the motherboard. You should lift the hard drive. Remove 2 cords and remove 2 screws. You’ve made it to the motherboard. You should lift the hard drive. Remove 2 cords and remove 2 screws. You’ve made it to the motherboard.
    • You should lift the hard drive. Remove 2 cords and remove 2 screws. You’ve made it to the motherboard.
  5. Now remove this cord and remove the 2 screws holding the power supply. Yup that’s the power supply. Now remove this cord and remove the 2 screws holding the power supply. Yup that’s the power supply. Now remove this cord and remove the 2 screws holding the power supply. Yup that’s the power supply.
    • Now remove this cord and remove the 2 screws holding the power supply. Yup that’s the power supply.
  6. Take out 2 remaining cords and 4 cords shown in this picture. Look at how many screws you need to remove. Take out 2 remaining cords and 4 cords shown in this picture. Look at how many screws you need to remove. Take out 2 remaining cords and 4 cords shown in this picture. Look at how many screws you need to remove.
    • Take out 2 remaining cords and 4 cords shown in this picture. Look at how many screws you need to remove.
  7. And finally take out the big green motherboard. And finally take out the big green motherboard. And finally take out the big green motherboard.
    • And finally take out the big green motherboard.
Tyler Worwa
357 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
that was easy thank you
tostypinapple - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 200
