Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. ZEBCO 202k cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. ZEBCO 202k Teardown, ZEBCO 202k Teardown: adım 1, 1 resimden 1.
    • remove front cover assembly (red cap)
    • turn assembly cap counterclockwise
  2. ZEBCO 202k Teardown: adım 2, 1 resimden 1.
    • Takeoff spinner head assembly. (metal cap)
    • Hold the handle and turn spinner head assembly counterclockwise
  3. ZEBCO 202k Teardown: adım 3, 3 resimden 1. ZEBCO 202k Teardown: adım 3, 3 resimden 2. ZEBCO 202k Teardown: adım 3, 3 resimden 3.
    • Use flat head to remove the spool clip
    • remember order of washers for assembly.
    • after removing spool clip washer, you can also pull out spool
  4. ZEBCO 202k Teardown: adım 4, 3 resimden 1. ZEBCO 202k Teardown: adım 4, 3 resimden 2. ZEBCO 202k Teardown: adım 4, 3 resimden 3.
    • Underneath the spool there will be a thin washer and a drag adjuster spring.
    • lift up to remove
  5. ZEBCO 202k Teardown: adım 5, 2 resimden 1. ZEBCO 202k Teardown: adım 5, 2 resimden 2.
    • Using the flat head unscrew drag actuator.
    • Will need to hold the drag nob down to keep it from moving.
  6. ZEBCO 202k Teardown: adım 6, 3 resimden 1. ZEBCO 202k Teardown: adım 6, 3 resimden 2. ZEBCO 202k Teardown: adım 6, 3 resimden 3.
    • remove back assembly from body assembly by pushing up oppisites side off handle
    • no tools are needed
  7. ZEBCO 202k Teardown: adım 7, 2 resimden 1. ZEBCO 202k Teardown: adım 7, 2 resimden 2.
    • remove spring from center shaft by pulling it by hand or help of flat head
    • center shaft will fall from the middle
  8. ZEBCO 202k Teardown: adım 8, 1 resimden 1.
    • unscrew handle to remove driven gear and to remove anti reverse.
  9. ZEBCO 202k Teardown: adım 9, 1 resimden 1.
    • insert driven and anti revers screw and reconnect handle.
  10. ZEBCO 202k Teardown: adım 10, 1 resimden 1.
    • slide in back assembly
    • screw in drag nob and drag actuator
  11. ZEBCO 202k Teardown: adım 11, 3 resimden 1. ZEBCO 202k Teardown: adım 11, 3 resimden 2. ZEBCO 202k Teardown: adım 11, 3 resimden 3.
    • insert drag adjuster spring
    • then thin washer
    • spool then red washer and the last whasher
    • at the top you will need to clip in spool clip.
  12. ZEBCO 202k Teardown: adım 12, 1 resimden 1.
    • turn spinner head assembly till lock into place
    • put front cover assembly back on
Ekli Belgeler
Daniel
205 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 150
