Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. canon PowerShot SX150 IS cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. canon PowerShot SX150 IS Teardown, How to start: adım 1, 3 resimden 1. canon PowerShot SX150 IS Teardown, How to start: adım 1, 3 resimden 2. canon PowerShot SX150 IS Teardown, How to start: adım 1, 3 resimden 3.
    • Start by removing the screws of the back side of the camera.
    • Try to remember where each screw goes keep in mind there small keep them safe
    • when removing screws make sure you remove them all if one screw is still there you may break the camera check in all sides to be sure. yes there are screws on the sides and on the bottom of the camera
    • be care full when removing this item
  2. canon PowerShot SX150 IS Teardown, Removal of an important metal: adım 2, 3 resimden 1. canon PowerShot SX150 IS Teardown, Removal of an important metal: adım 2, 3 resimden 2. canon PowerShot SX150 IS Teardown, Removal of an important metal: adım 2, 3 resimden 3.
    • remove the small screws that are in the sides of the buttons
    • this part of the camera is connected to the camera so don't pull it to harshly
    • now we remove the connection between the items if lifting up a tiny lock and pulling it out carefully.
  3. canon PowerShot SX150 IS Teardown, removing the screen: adım 3, 3 resimden 1. canon PowerShot SX150 IS Teardown, removing the screen: adım 3, 3 resimden 2. canon PowerShot SX150 IS Teardown, removing the screen: adım 3, 3 resimden 3.
    • we remove the screen by separating it's connection and remove the screws on the bottom of the screen
  4. canon PowerShot SX150 IS Teardown, removing the front of the camera: adım 4, 3 resimden 1. canon PowerShot SX150 IS Teardown, removing the front of the camera: adım 4, 3 resimden 2. canon PowerShot SX150 IS Teardown, removing the front of the camera: adım 4, 3 resimden 3.
    • check the bottom of the camera there will be two screws one will be visible the other one is where you insert the batteries.
    • check now the sides and the front of the camera there will be more screws in where the flash is remove them, then the camera should look like the picture shown.
  5. canon PowerShot SX150 IS Teardown, removing the item that holds it all: adım 5, 3 resimden 1. canon PowerShot SX150 IS Teardown, removing the item that holds it all: adım 5, 3 resimden 2. canon PowerShot SX150 IS Teardown, removing the item that holds it all: adım 5, 3 resimden 3.
    • there are many screws so we remove them all also we check the bottom there will be one screw we remove it as well
    • this is a very important part since this piece holds everything in place make sure you are careful with it
  6. canon PowerShot SX150 IS Teardown, the final connections/step: adım 6, 3 resimden 1. canon PowerShot SX150 IS Teardown, the final connections/step: adım 6, 3 resimden 2. canon PowerShot SX150 IS Teardown, the final connections/step: adım 6, 3 resimden 3.
    • now we finally disconnect the last parts that are assemble be careful these are sensitive parts
    • now we are finally done with the teardown
Iris Jimenez
141 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 807
