Ana içeriğe geç
Yardım
Adım 8 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
The IP25 board contains 4 MIPS R10000 processors, running at 195Mhz with 2MB of cache on-die.
The CPU chip is mounted to an HIMM PCB. The connections are made with a Cinch CIN::APSE, which appears similar to an LGA socket, except nothing holds the "pins" (bits of steel wool) in place when they are not connected. DO NOT REMOVE the HIMMs unless required, and INSPECT the connector with a microscope during reassembly! The pins are easy to lose or short out!
Mips R10000 processor
Everest data bus ASICs
Everest address bus ASIC
5V power converter
3.3V power converters
glue logic and microcode eproms
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
