Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Yardım
Adım 2 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Stacked up like pancakes, you'll notice the new MacBook Pro is noticeably bigger (and just a hair thicker) than the latest 15" model. It actually compares well with the 2015 model—in size that is, not port selection.
With the 16" Pro back-to-back against the 2015 Pro, you're almost seeing double ... until you look closer. The display hinge has changed, and the old Pro's keys peek out just a bit more.
In a similar game of "spot the differences" between the two 2019 MacBook Pros, the 16" version gets:
A physical Esc key, separated from the Touch Bar
A matte finish on the Touch ID/power button, matching the rest of the keys
A Touch Bar shortened in length by about 19 mm
Inverted-T arrow keys, all half-sized
If you zoom and enhance the left grille, you can see the camouflaged holes for the improved triple-mic. And now, you can never un-see it.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
