Ana içeriğe geç
Yardım
Adım 9 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Remove 14 retaining screws from back
The first 9 are required for bezel and touchpad removal .
M2 × 14 mm, wafer-head, nylon-coated (6)
M2 × 3 mm, wafer-head, nylon-coated (3)
The remaining need to be removed for base cover removal
M2 × 5 mm, wafer-head, nylon-coated (4)
M2 × 10 mm, wafer-head, nylon-coated (1)
Note: The FPC cable is attached on the underside of the keyboard bezel assembly. In some models, the Bluetooth daughter card is also attached on the underside of the keyboard bezel assembly.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
