Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Yardım
Adım 23 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
iPad 2 Repairability Score: 2 out of 10 (10 is easiest to repair)
The LCD is really easy to remove once the front panel is gone.
Only standard Phillips screws were used -- no Pentalobular or Tri-Wing funny-business.
The front panel is now glued to the rest of the device, greatly increasing the chances of cracking the glass when trying to remove it.
The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
The battery is very securely stuck down to rear case, and you have to remove the logic board to remove it.
You can't access the front panel's connector until you remove the LCD.
Historical note: We initially awarded the iPad 2 a 4 out of 10, but in the process of writing our repair manual realized that it was far more difficult to repair than originally suspected.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
