Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Yardım
Adım 3 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Insert wisdom here.
Only pry at the front end of the keyboard, as there are easily damaged ribbon cables at the rear of the keyboard.
Using a heat gun on low setting can be used carefully to heat the rear cover and soften the adhesive. Work in sections heating and then gradually prying the sections apart.
Avoid using too much heat otherwise you will distort or melt the cover or other plastic parts. Do not use excessive force to remove the cover as the alloy is thin and bends easily. The keyboard will be permanently distorted.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
