Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. iMac G3 Model M4984 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iMac G3 Model M4984 Teardown, Logic Board: adım 1, 1 resimden 1.
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Teardown: adım 2, 1 resimden 1.
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Teardown: adım 3, 3 resimden 1. iMac G3 Model M4984 Teardown: adım 3, 3 resimden 2. iMac G3 Model M4984 Teardown: adım 3, 3 resimden 3.
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Teardown: adım 4, 3 resimden 1. iMac G3 Model M4984 Teardown: adım 4, 3 resimden 2. iMac G3 Model M4984 Teardown: adım 4, 3 resimden 3.
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Teardown: adım 5, 3 resimden 1. iMac G3 Model M4984 Teardown: adım 5, 3 resimden 2. iMac G3 Model M4984 Teardown: adım 5, 3 resimden 3.
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Teardown: adım 6, 2 resimden 1. iMac G3 Model M4984 Teardown: adım 6, 2 resimden 2.
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Teardown: adım 7, 3 resimden 1. iMac G3 Model M4984 Teardown: adım 7, 3 resimden 2. iMac G3 Model M4984 Teardown: adım 7, 3 resimden 3.
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Teardown: adım 8, 1 resimden 1.
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Teardown, Bottom Cover: adım 9, 1 resimden 1.
    • To remove the bottom cover, remove these phillips screws, and pull the bottom cover off the iMac. (Start with the very back and use a flat head screwdriver to pop the main clip. The rest will come off relatively easily.)
  10. iMac G3 Model M4984 Teardown: adım 10, 3 resimden 1. iMac G3 Model M4984 Teardown: adım 10, 3 resimden 2. iMac G3 Model M4984 Teardown: adım 10, 3 resimden 3.
    • Removing the faceplate:
    • Remove these phillips screws.
    • Now, pivot the faceplate up about 60 degrees and pull it away from the imac, with some wiggleing, it should come free
Chris Green
37.777 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
1Rehber Yorum
yo what happened to this lmao
Crystal Haugh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 27
Son 30 gün: 98
Her zaman: 10,048
