Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. iPad 4 Wi-Fi cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iPad 4 Wi-Fi Teardown, iPad 4 Wi-Fi Teardown: adım 1, 1 resimden 1.
    • Welcome, ladies and gentlemen.
    • Apple has stunned the tech world once again. A mere 7 months after the announcement of the iPad 3, the iPad 4 was introduced on October 23, 2012.
    • Tech Specs:
    • Dual-core A6X processor with quad-core GPU
    • 9.7 inch LCD, backlit in-plane switching LED with 2048×1536 pixel Retina display
    • 16, 32, or 64 GB flash memory (at launch)
    • 5 MP rear-facing camera
    • Lightning connector
  2. iPad 4 Wi-Fi Teardown: adım 2, 2 resimden 1. iPad 4 Wi-Fi Teardown: adım 2, 2 resimden 2.
    • One of the major differences between the 3rd and 4th generation iPads is the connector. The 3rd gen (top) has the 30-pin dock connector, while the 4th gen (bottom) has the Lightning connector.
    • The iPad 4 has a new model number, A1458.
  3. iPad 4 Wi-Fi Teardown: adım 3, 1 resimden 1.
    • Continuing the trend, this iPad is glued shut. This isn't our first adhesive-riddled iPad, and we've been working to figure out how to make the painful opening process a lot easier.
    • Our heated-up iOpener lets us apply heat just where it's needed, softening the troublesome adhesive. Once we've snuck a few guitar picks in the seam, we're nearly home-free.
    • We're happy to report that no iPads were cracked in the creation of this teardown. We haven't always been so fortunate.
  4. iPad 4 Wi-Fi Teardown: adım 4, 3 resimden 1. iPad 4 Wi-Fi Teardown: adım 4, 3 resimden 2. iPad 4 Wi-Fi Teardown: adım 4, 3 resimden 3.
    • With the adhesive out of the way, we open up the iPad.
    • As expected, this stage looks no different from the previous generation.
    • Now that the hard part is out of the way, it's time for a break with a hot cup of drinking chocolate.
  5. iPad 4 Wi-Fi Teardown: adım 5, 2 resimden 1. iPad 4 Wi-Fi Teardown: adım 5, 2 resimden 2.
    • As opposed to the Samsung display we found in the iPad 3, the new iPad LCD is manufactured by LG.
    • Apple has reportedly been working to move away from Samsung as a primary supplier, so this LG display is not surprising. However, Apple often relies on multiple suppliers for a single component, meaning there are quite likely other LCD manufacturers lurking inside other iPad 4s.
  6. iPad 4 Wi-Fi Teardown: adım 6, 1 resimden 1.
    • Continuing to examine differences in the LCD cables…
    • Well, Apple used a different color Sharpie.
  7. iPad 4 Wi-Fi Teardown: adım 7, 2 resimden 1. iPad 4 Wi-Fi Teardown: adım 7, 2 resimden 2.
    • We lift up the LCD to reveal the battery.
    • The battery is labeled with the same model number (A1389) as in the last round, so it's no surprise that it's another 3.7 V, 43 Whr package.
    • Like the iPad 3, the battery is adhered very securely to the rear case. Since batteries are consumables that wear out, the trend of glued-in, hard-to-access batteries in iPads and other Apple devices is unfortunate.
  8. iPad 4 Wi-Fi Teardown: adım 8, 1 resimden 1.
    • Skipping ahead to the good stuff, we get a quick look at the biggest improvement in the iPad 4—the A6X and its supporting hardware:
    • Apple A6X Processor
    • SK Hynix H2JTDG8UD2MBR 16 GB NAND Flash
    • Apple 338S1116 Cirrus Logic Audio Codec
    • 343S0622-A1 Dialog Semi PMIC
    • Apple 338S1077 Cirrus Logic Class D Audio Amplifier
    • QVP TI 261 A9P2 Boost Converter (likely)
  9. iPad 4 Wi-Fi Teardown: adım 9, 1 resimden 1.
    • The backside of the board, however, boasts no dramatic improvements:
    • Broadcom BCM5974 Touch Screen Controller
    • Broadcom BCM5973A1 Touch Screen Controller
    • Texas Instruments CD3240B0 Touch Screen Line Driver
    • 2 x 4Gb Elpida LP DDR2 = 1 GB DRAM in separate packages in a 64-bit configuration
    • 2 x Fairchild BCHAH/FDMC Voltage Regulator / Reference
    • Murata 339S0171 Broadcom BCM4334 WiFi Module
  10. iPad 4 Wi-Fi Teardown: adım 10, 1 resimden 1.
    • Apple didn't save any space by switching to the smaller Lightning connector (lower); rather they let the Lightning cable sit in a frame the same size as the 30-pin dock connector (upper).
    • We were hoping that space savings would yield bigger, better speakers. Very disappointing, indeed.
  11. iPad 4 Wi-Fi Teardown: adım 11, 3 resimden 1. iPad 4 Wi-Fi Teardown: adım 11, 3 resimden 2. iPad 4 Wi-Fi Teardown: adım 11, 3 resimden 3.
    • If you're new to our site, we'll let you in on a little secret: we love our 54 Bit Driver Kit. It makes quick work freeing the Lightning connector, even with a couple of hard to find screws.
    • There is a bit of adhesive holding the connector in, but nothing compared to some adhered components we've seen before.
    • Repair techs, DIY-ers, and clumsy iPad-users, rejoice! The Lightning connector is on its very own ribbon cable, meaning that procuring a replacement connector should be fairly inexpensive.
  12. iPad 4 Wi-Fi Teardown: adım 12, 2 resimden 1. iPad 4 Wi-Fi Teardown: adım 12, 2 resimden 2.
    • Despite looking almost identical in this shot, we do spot one more difference between the 3rd (top) and 4th (bottom) generations: the front-facing camera!
    • We've got a 1.2MP FaceTime HD camera, with the ability to shoot 720p HD video. That's a big improvement from the .3MP FaceTime camera in the iPad 3.
    • Compared to the iPad 3, this camera is actually slightly thicker (an extra .4 mm), but it still manages to fit into the same space.
  13. iPad 4 Wi-Fi Teardown: adım 13, 2 resimden 1. iPad 4 Wi-Fi Teardown: adım 13, 2 resimden 2.
    • iPad 4 Repairability Score: 2 out of 10 (10 is easiest to repair)
    • The LCD is easy to remove once the front panel is gone.
    • The battery is not soldered to the logic board, making the replacement process a tad less difficult.
    • Just like in the iPad 2 & 3, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass when trying to remove it.
    • Gobs, gobs, and gobs of adhesive hold everything in place, including the prone-to-start-a-fire-if-punctured battery.
    • The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
    • You can't access the front panel's connector until you remove the LCD.
14 Comments
home 键是最大的改变
Green Zhu - Yanıt
Be careful with the home button flex!
iTiger Repair - Yanıt
I know! I tore mine. Does anyone know where to get a replacement?
Aliases Poopoo -
can the home button flex be torn taking the glass out or is it if your trying to remove the flex it's self.
keith -
I assume also from because they dont comment on the glass that it is the same as the ipad 3 glass?
keith -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 65
Son 30 gün: 236
Her zaman: 244,701
