Giriş
You probably expected a thinner, lighter, and faster iPad Air 3, but Apple had other ideas. Instead of iterating on October 2014's iPad Air 2, they went back to the drawing board. Actually they probably don't use a drawing board, they use an iPad Pro—which might be where they got the idea for this. It seems to pack all the features of the first iPad Pro, in a smaller package. Let's see how they did it—it's time to tear down the iPad Pro 9.7".
Follow us on Facebook, Instagram, or Twitter for the latest teardown news.
Videoya Genel Bakış
Apple may have let all the Air out of the iPad line, but they didn't skimp on the 9.7" Pro's specs:
Fully laminated, 9.7", LED-backlit, Oxide TFT "True Tone" display with 2048 x 1536 resolution (264 ppi)
3rd generation 64-bit Apple A9X custom processor, with M9 motion coprocessor
12 MP rear iSight camera with 4K video recording at 30 fps, and 5 MP FaceTime camera with 720p video
Self-balancing, four-speaker audio
Touch ID sensor, 2 microphones, 2 ambient light sensors, accelerometer, barometer, and 3-axis gyro
802.11a/b/g/n/ac MIMO Wi-Fi + Bluetooth 4.2
32, 128, or 256 GB of on-board storage
Before sinking our
teethpicks into this thing, we check out our favorite website to get a look at the True Tone display. -
Of course, what sleek, new mobile offering out of Cupertino would be complete without the infamous camera bump?
And, for the second time this week, the Rose Gold rear case shows off a new model number: A1673, and the usual regulatory markings.
No surprise, once it reaches its 5th birthday, Apple doesn't want you pitching your iPad into the nearest trash can—they'd prefer you give it back.
The whole iPad family is here! Left to right: Mini 3, Air 2, and iPad Pro 12.9".
Truly, in its entire history, there has never been a more Rose Gold iPad than this.
In all seriousness, it's refreshing to see a redesign that seems to focus on features rather than a nigh-pointless reduction in thickness, in a device that's already thinner than a pencil.
Our ingenious friends at Creative Electron sent us a sneak peek at the Pro 9.7's internals, X-ray style.
We immediately note that where the larger iPad Pro's interior volume was dominated by four huge speaker enclosures, this little guy uses a more conventional setup: the battery hogs most of the space, with the logic board on the side and the speakers squeezed in at the margins.
What's that weird strip of PCB running through the middle, though?
Time for a closer look. Let's open it up!
Survey says: Display cable's in the bottom right corner! That's a new configuration.
We'd like to take a brief moment to mention that disassembly instructions are hugely important for successful repairs. We believe every user has the right to know how to safely work on their device.
The display, backed with some cushioning foam, also contains a ton of chips!
Parade Technologies DP815 (likely an iteration of the DP695 timing controller found in the 12.9" Pro)
NXP Semiconductors 8416A1 (NVT8416) secure microcontroller (for Touch ID)
Renesas ISL98667A display power management
After popping a few screws, we remove a big slab of EMI shield covering the logic board.
Our fingers are itching for chips, but for now we restrain ourselves and settle for isolating the battery. One precisely-placed pick separates the battery contacts from the logic board.
Next to come off is another shield covering the battery board, nestled between the two large battery cells.
With shields and tape deftly dispatched, we turn our attention to the heavy hitters. First up: upper speakers!
They're really fiercely glued in, and screwed in, but it's nothing a plastic opening tool can't deal with.
Once we pop the speakers out for a closer look, we're rewarded for our hard work: they connect to the logic board with spring contacts!
Out pops the perpetrator of that unsightly camera bump.
And yup, that dimple goes all the way down, through the case down to the sapphire crystal lens cover.
Recently, there have been a number of consolidated hardware features in Apple's mobile lineup and this camera is no exception.
It's the same 12 MP, 4K shooter featured in the 6s—a substantial upgrade over the 8 MP 1080p camera we dug up in our last Pro teardown.
On our way to the logic board, we encounter some strange new antenna interconnect boards.
A dab of glue fastens each connector in place, but they come free with a little gentle prying.
The boards themselves serve no obvious purpose; we can only speculate that their flat tops provide a little extra support for the display.
Anyway, time to get a look at that logic board!
Chip chip hooray!
Apple APL1021 A9X 64-bit applications processor
Samsung K3RG1G10BM-KGCH 2 GB (16 Gb) LPDDR4 SDRAM memory
SK Hynix H23QEG8VG1ACR-BC 32 GB (256 Gb) NAND flash memory
2 × Broadcom BCM15900B0 (as seen in the iPad Pro 12.9") touchscreen controller
Apple 339S00109 Wi-Fi module
NXP 66V10 (PN66V) NFC controller and 1610A3 charging IC (as seen in iPhone SE/6s/6s Plus) (CBTL1610A3, possibly a display port multiplexer)
InvenSense EMS-A 6-axis gyroscope and accelerometer combo (also found in iPhone SE)
But wait, there's even more chips!
Maxim Integrated MAX98721BEWV boosted class amplifier
M7H YP (likely a Bosch Sensortec BMP280) (BMP282 pressure sensor)
Apple 343S00051-A1 (likely an iteration of the 343S00052-A1 found in the iPad Pro 12.9") power management
Apple 343S00089-A1 power management
STMicroelectronics STM32L052T8 32-Bit ARM Cortex-M0+ microcontroller
Cirrus Logic CS42L83A audio codec
Analog Devices ADAU7002 audio converter
Unfortunately for repair-minded folks like ourselves, the battery contains none of those nifty adhesive pull tabs found in the larger iPad Pro (and in every iPhone since the 5s). So, removing it is a sticky affair.
Maybe next time Apple? Pretty please?
What the battery does contain is a rating of 3.82 V, 27.91 Wh, and 7,306 mAh, amounting to a 10-hour battery life claim.
We're about to leave the case at that, but we try another poke at the Smart connector, hoping for an easier extraction than last time. No such luck.
Texas Instruments SN27545 Battery Fuel Gauge
iPad Pro Repairability Score: 2 out of 10 (10 is easiest to repair)
While not soldered in place, the battery is very solidly adhered—no more pull tabs like we saw in the larger iPad Pro 12.9"
The Smart Connector port is virtually impossible to replace—but incorporates no moving parts and is unlikely to fail.
The LCD and front panel glass are fused together. This slightly simplifies the opening procedure.
The fused front panel increases the cost of screen repair, and the risk of damaging the LCD when opening.
Gobs of adhesive hold everything in place making all repairs more difficult.
43 Comments
No mention of the new integrated Apple SIM?
They tore down the wifi model, so no SIM.
Anyone have a good image of the embedded Apple SIM? I need to know exactly where it is in the iPad Pro 9.7 and 10.5.
joshe -
What about the USB controller, 3.0 or 2.0?
