Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. iPhone 12 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iPhone 12  Teardown, Remove the SIM: adım 1, 2 resimden 1. iPhone 12  Teardown, Remove the SIM: adım 1, 2 resimden 2.
    • Using a SIM extractor remove the support for the SIM card.
  2. iPhone 12  Teardown, Unscrew the lower screws: adım 2, 3 resimden 1. iPhone 12  Teardown, Unscrew the lower screws: adım 2, 3 resimden 2. iPhone 12  Teardown, Unscrew the lower screws: adım 2, 3 resimden 3.
    • Turn off the device
    • Unscrew the two 6.9 mm long Pentalobe screws.
  3. iPhone 12  Teardown, Raise the display: adım 3, 3 resimden 1. iPhone 12  Teardown, Raise the display: adım 3, 3 resimden 2. iPhone 12  Teardown, Raise the display: adım 3, 3 resimden 3.
    • Apply a heated iOpener all around the edge of the screen to loosen the adhesive under the display.
    • Lift the display with a suction cup and insert a thin object to separate the screen from the frame.
    • Slide the fine object along the entire edge to cut the adhesive.
    • Raise the display.
  4. iPhone 12  Teardown, Disconnect the display: adım 4, 3 resimden 1. iPhone 12  Teardown, Disconnect the display: adım 4, 3 resimden 2. iPhone 12  Teardown, Disconnect the display: adım 4, 3 resimden 3.
    • Remove the 6 Phillips # 00 screws.
    • With a spudger or with your fingernails, lift the two connectors.
    • Lift the connector underneath.
    • Disconnect the display connector.
  5. iPhone 12  Teardown, Remove the rear camera: adım 5, 3 resimden 1. iPhone 12  Teardown, Remove the rear camera: adım 5, 3 resimden 2. iPhone 12  Teardown, Remove the rear camera: adım 5, 3 resimden 3.
    • Unscrew the 4 Phillips # 00 screws.
    • With a spudger or fingernails disconnect the two rear camera connectors.
    • Remove the rear camera.
  6. iPhone 12  Teardown, Remove the front camera.: adım 6, 2 resimden 1. iPhone 12  Teardown, Remove the front camera.: adım 6, 2 resimden 2.
    • With a spudger or fingernails to disconnect the three connectors that connect the front camera.
    • Remove the front camera.
  7. iPhone 12  Teardown, Remove the battery holder: adım 7, 2 resimden 1. iPhone 12  Teardown, Remove the battery holder: adım 7, 2 resimden 2.
    • With a spudger or fingernails disconnect the battery holder connector.
    • Unscrew the 3 Phillips # 00 screws.
    • Remove the battery holder.
  8. iPhone 12  Teardown, Remove the camera flash: adım 8, 1 resimden 1.
    • With a spudger or fingernails disconnect the rear camera flash connector.
    • Unscrew the 2 Phillips # 00 screws.
    • Remove the rear camera flash.
  9. iPhone 12  Teardown, Remove the SIM card holder: adım 9, 3 resimden 1. iPhone 12  Teardown, Remove the SIM card holder: adım 9, 3 resimden 2. iPhone 12  Teardown, Remove the SIM card holder: adım 9, 3 resimden 3.
    • Unscrew the 2 screw holders with the suitable screwdriver.
    • With a spudger or fingernails to disconnect the SIM card holder connector.
    • Remove the SIM card holder.
  10. iPhone 12  Teardown, Remove the battery logic board: adım 10, 2 resimden 1. iPhone 12  Teardown, Remove the battery logic board: adım 10, 2 resimden 2.
    • Remove the 2 Phillips # 00 screws.
    • With a spudger or fingernails disconnect the 3 battery connectors.
    • Unscrew the screw holder with a standoff screwdriver for iphone.
    • Remove the film with a spudger.
    • Attention this last step is necessary to remove the logic board.
    • Remove the logic board.
  11. iPhone 12  Teardown, Remove the speaker: adım 11, 2 resimden 1. iPhone 12  Teardown, Remove the speaker: adım 11, 2 resimden 2.
    • Unscrew the 5 Phillips # 00 screws.
    • Remove the speaker.
  12. iPhone 12  Teardown, Remove the taptic engine: adım 12, 2 resimden 1. iPhone 12  Teardown, Remove the taptic engine: adım 12, 2 resimden 2.
    • Remove the 2 screw holders with a standoff screwdriver for iphone
    • Remove the taptic engine connector with a spudger or fingernail.
    • Remove the taptic engine.
  13. iPhone 12  Teardown, Remove the battery: adım 13, 2 resimden 1. iPhone 12  Teardown, Remove the battery: adım 13, 2 resimden 2.
    • Remove the adhesive under the battery.
    • To remove the adhesive under the battery, remove the stickers marked in red in the first photo.
    • Remove the battery.
  14. iPhone 12  Teardown, Remove the charging card: adım 14, 2 resimden 1. iPhone 12  Teardown, Remove the charging card: adım 14, 2 resimden 2.
    • Unscrew 6 Phillips # 00 screws.
    • Remove the 4 screw holders with an iphone standoff screwdriver.
    • Attention, the previous step is essential to remove the charging card.
    • Remove the charging card.
    • Be careful not to make too strong, this could damage some components.
  15. iPhone 12  Teardown: adım 15, 1 resimden 1.
    • And here are all the components that make up the new iPhone 12.
Bu çevirmenlere özel teşekkürler:
it en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Andrea Alfani
5.499 İtibar
4 adet Kılavuz yazıldı
Kid fixers Kid fixers üyesi
Community
134 Üyeler
177 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 34
Son 7 gün: 253
Son 30 gün: 1,169
Her zaman: 7,621
