Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. iPhone 5 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iPhone 5 Teardown, iPhone 5 Teardown: adım 1, 3 resimden 1. iPhone 5 Teardown, iPhone 5 Teardown: adım 1, 3 resimden 2. iPhone 5 Teardown, iPhone 5 Teardown: adım 1, 3 resimden 3.
    • The dawn of another day in the Land Down Under brings us what we've all been waiting for: the new iPhone 5!
    • A big thanks to MacFixit Australia for letting us use their digs in Melbourne for this teardown. They stock Mac and iPhone upgrades/accessories, and also carry our iFixit toolkits.
    '''Techno Related''' now imagine reassembling it a few hundred times and that's your average day at foxconn....oh and you're 12 years old...
    Techno Related - Yanıt
  2. iPhone 5 Teardown: adım 2, 2 resimden 1. iPhone 5 Teardown: adım 2, 2 resimden 2.
    • The iPhone 5 is here, and it brought along the big guns.
    • 4" 1136x640 pixel (326 ppi) Retina display
    • Apple A6 system on a chip (SoC)
    • 8 megapixel iSight camera
    • 8-pin Lightning connector
    • 4G LTE connectivity
    • iOS 6
    can you test to see how easy the black comes off from the case.. Big question in forums called "Scuff Gate"
    chrisfromalbany - Yanıt
    I replaced the battery. But only last week I put it on charge. With genuine apple charger. But in the morning the battery had swollen up. Popping the screen.. I still have my i fixit tool kit so i checked the battery and it was soft like jelly. I checked about replacement and I was directed to the Australian site. Where the price is double the price i paid for the same battery i had sent from I fixit in CA. Also the postage in Australia. Was over "$15 dollars. Looks like the Australian store is robbing us locals and the last one from the US WAS shipped by air … Would management care to explain . The reasons.. ?????
    hughgray - Yanıt
  3. iPhone 5 Teardown: adım 3, 1 resimden 1.
    • There won't be any mistaking an iPhone 5 for an iPhone 4 or 4S. A lot has changed on the outside of the iPhone.
    • The most obvious alteration to the bottom of the phone is the exchange of the large 30-pin dock connector for the diminutive Lightning connector.
    • The headphone jack is now on the bottom of the iPhone, right next to the updated speaker microphone grille—a series of holes rather than a mesh-covered slot.
    • Other notable differences are the slate bezel, as opposed to the stainless steel that wrapped around the 4S, and the chamfered edges between the bezel and the front/rear cases.
  4. iPhone 5 Teardown: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    P2 Pentalobe Screwdriver iPhone
    $5.99
    Satın Al
    • Pesky pentalobe screws! Good thing our 5-Point Drivers still work on them.
    • It's incredibly convenient that Apple used the same pentalobe screwhead that they've been using for the past two years on the iPhone 4 and 4S. The screw shafts are slightly different from the screws in our iPhone 4/4S Liberation Kit, so we made a new iPhone 5 Liberation Kit!
    • The unibody back case is reminiscent of the iPhone 3GS, while still retaining the square (though now chamfered) edges of the iPhone 4.
    a heads up about the volume/silent button/ power button ribbon cable that runs width wise under the upper part of the battery would have been AWESOME, you can just change step 9 to broke my phone...
    Allan - Yanıt
  5. iPhone 5 Teardown: adım 5, 2 resimden 1. iPhone 5 Teardown: adım 5, 2 resimden 2.
    • What's this? A suction cup? We haven't needed a suction cup to get into an iPhone since the 3GS!
    • Because the iPhone 5 is opened front-to-back, replacing a cracked screen is going to be easier than ever. Thank you, Apple!
    • Compare this to the iPhone 4S, where it took 38 steps to isolate the display assembly, and this iPhone may be the most repairable iPhone we've seen in a while.
    Can we give the iPhone 5 a tentative 9 out of 10 just because of the screen? It already looks more repairable than the Retina MBP.
    plink53 - Yanıt
  6. iPhone 5 Teardown: adım 6, 2 resimden 1. iPhone 5 Teardown: adım 6, 2 resimden 2.
    • The display connector is held firmly to the logic board by a few simple Phillips screws.
    • Our spudger makes quick work of prying up the display connector, and poof! the display is free.
    • We're having iPhone 3GS flashbacks with the easily accessible display assembly.
    • Screen crackers and screen fixers rejoice!
    I have noticed that the 3 screws that remove the plate that connects the digitizer and the glass , 2 of which are magnetic and one 1 non magnetic, does anyone know the reason for this?
    Brennan Babb - Yanıt
    I read somewhere here that it's to prevent GPS interference, as the GPS module is located right next to it.
    stretchymantis -
    Uhh just a quick one! I was not paying attention as to which hole the non magnetised screw came out of. Can anyone tell me which hole it came out of please?
    tyronne888 - Yanıt
  7. iPhone 5 Teardown: adım 7, 2 resimden 1. iPhone 5 Teardown: adım 7, 2 resimden 2.
    • The iPhone 5 ditches its lid to show us all of the juicy bits inside.
    • So, what can we see from here? A bigger battery? Antenna connections? A single speaker? Cameras? Vibrators? Home buttons?
    • Never fear, our faithful iPhone delivers; we'll be sure to take a closer look at each of these components as we remove them.
  8. iPhone 5 Teardown: adım 8, 1 resimden 1.
    • As always, we disconnect the battery first to prevent electrifying anything, including ourselves, as we dig deeper.
    • Three Phillips #000 screws and a metal bracket hold the battery connector to the logic board.
    • Hmm, this is beginning to feel very familiar.
    • In the 3GS, the display assembly was easy to take out, but the battery was a pain. In the 4 and 4S, the display assembly took 38 steps to remove, while the battery was a breeze. We like to think that Apple has started tailoring to our preferences in allowing us to remove both the display assembly and the battery in only a couple of steps.
  9. iPhone 5 Teardown: adım 9, 3 resimden 1. iPhone 5 Teardown: adım 9, 3 resimden 2. iPhone 5 Teardown: adım 9, 3 resimden 3.
    • We use the Battery removal tab to pull up the battery. Never try to pry soft pack batteries as this could lead to a thermal event!
    • For the iPhone 5, Apple has switched to a different battery chemistry, with a higher voltage and slightly larger capacity than the iPhone 4S. Let's see how the battery specs stack up.
    • iPhone 5 Battery: 3.8V - 5.45Wh - 1440mAh. Talk time: Up to 8 hours on 3G. Standby time: Up to 225 hours.
    • iPhone 4S Battery: 3.7V - 5.3Wh - 1432mAh. Talk time: Up to 8 hours on 3G. Standby time: Up to 200 hours.
    • Samsung Galaxy S III Battery: 3.8V - 7.98Wh - 2100mAh. Talk time: Up to 11 hours 40 minutes on 3G. Standby time: Up to 790 hours.
    • On the back of the battery we notice "MFR Sony," and "Cell made in Singapore." A bit of googling and it looks very likely that Sony is manufacturing this battery.
    Does anyone have the X,Y,and Z dimensions of the battery? The battery is clearly bigger than the iPhone4 battery in the XY dimension and I am wondering if it got thicker or thinner for the iPhone5.
    gary - Yanıt
    I was looking at the conversion for 5.45 Wh to mAh and noticed that the value is actually closer to 1434 mAh when using the following math: (5.45Wh * 1000)/3.8V ≈ 1432 mAh. Am I missing something?
    Kaz Kimura - Yanıt
    Wrong picture in middle one, that one is Iphone 4S batt.
    Queens BB - Yanıt
    Hi, what is the physical size of the iphone 5 battery (LxWxH)? I can find this info for older iphones but can't seem to find for this one. thx!
    yoshi chin - Yanıt
    Theres no removal tab on my battery. Could someone have been in my phone before?
    Black Hat - Yanıt
  10. iPhone 5 Teardown: adım 10, 2 resimden 1. iPhone 5 Teardown: adım 10, 2 resimden 2.
    • There are all kinds of metal-to-metal contacts inside the iPhone 5.
    • Spring contacts make for easy repairs, but mandate careful attention to cleaning all the parts before reassembly. Finger oils can get in the way of these metal contacts and cause frustrating component failures.
    • This contact connects the metal frame around the front-facing camera to the frame around the rear-facing camera. Maybe this frame is some kind of an antenna? Only time will tell.
    • Speaking of antennas, a spudger easily pries one end of an antenna connector off of the logic board near the battery.
    • In the iPhone 4S, this antenna location was reserved for the cellular antenna. We won't know for sure what this antenna's purpose is until we uncover more.
    What is the little metal box on the top right called
    Jordan Higgins - Yanıt
    Back camera?
    Vatsan - Yanıt
  11. iPhone 5 Teardown: adım 11, 3 resimden 1. iPhone 5 Teardown: adım 11, 3 resimden 2. iPhone 5 Teardown: adım 11, 3 resimden 3.
    • Near the top of the case, we find a few antenna connectors firmly screwed to the inside of the case.
    • Finally free of its constraints, we lift the logic board up out of the rear case.
    • The logic board and 8 megapixel iSight camera come out together, leaving several components behind in the rear case—another win for modularity.
    • +1 for repairability.
  12. iPhone 5 Teardown: adım 12, 1 resimden 1.
    • They (product placement engineers) said if we tech writers were good and we stayed late, we can have one beverage of choice when we finished the teardown.
    • Then they promptly took the beverages away…
    • and put them in the fridge!!!
    • We Я happy camperz.
  13. iPhone 5 Teardown: adım 13, 2 resimden 1. iPhone 5 Teardown: adım 13, 2 resimden 2.
    • Many of the components that came out with the logic board are held in place with screws and brackets.
    • Apparently, Apple is very concerned with making sure that all the connectors are firmly seated and won't rattle loose over time. Good on you, Apple.
    • Before we go any further: A mega thanks to Chipworks for sticking around into the wee hours of the night and helping us identify the packages on the logic board. Their handiwork (along with ours!) can be seen below.
  14. iPhone 5 Teardown: adım 14, 1 resimden 1.
    • The underside of the logic board is teeming with components.
    • Skyworks 77352-15 GSM/GPRS/EDGE power amplifier module
    • SWUA 147 228 RF antenna switch module
    • TriQuint 666083-1229 WCDMA / HSUPA power amplifier / duplexer module for the UMTS band
    • Avago AFEM-7813 dual-band LTE B1/B3 PA+FBAR duplexer module
    • Skyworks 77491-158 CDMA power amplifier module
    • Avago A5613 ACPM-5613 LTE band 13 power amplifier
    So, guessing by the Avago PA chips, is this a A1429 CDMA?
    And how about the internals for A1429 GSM and A1428 GSM?
    iFixit, any chance you can blow away another $650 x 2 for the other two models?
    Bhuv - Yanıt
    How do you remove the plates without messing them up? Looks like they are soldered on the motherboard.
    Angela Penaherrera - Yanıt
    Through either desoldering, cutting, or straightup ripping them off the board -- whichever method yields the least-destructive, but also speedy result.
    We love it when a motherboard has a frame that's soldered, and little covers that go on top of the frame. We can remove those without any damage whatsoever.
    Miroslav Djuric -
  15. iPhone 5 Teardown: adım 15, 2 resimden 1. iPhone 5 Teardown: adım 15, 2 resimden 2.
    • More chips on the underside of the logic board:
    • Qualcomm PM8018 RF power management IC
    • Hynix H2JTDG2MBR 128 Gb (16 GB) NAND flash
    • Apple 338S1131 dialog power management IC*
    • Apple 338S1117 Cirrus Logic Class D Amplifiers. The die inside is a Cirrus Logic device (second image) but it does not look like the audio codec.
    • STMicroelectronics L3G4200D (AGD5/2235/G8SBI ) low-power three-axis gyroscope—same as seen in the iPhone 4S, iPad 2, and other leading smart phones
    • Murata 339S0171 (based on Broadcom BCM4334) Wi-Fi module
    Apple 338S1117 chip can't be Elpida memory MCP for LTE, because the LTE chipset in on the other edge of the board.
    miguel angel - Yanıt
    In addition to Alexander Zuev comment : is the GPS chipset BCM47511, or a new combo one?
    Francis - Yanıt
    The response is: No! Qualcomm MDM9615M is a Gobi™ modem which includes a built-in GPS chip GLONASS enable. No specs are available for this chip (sensitivity, number of channels, SBAS)
    Francis -
  16. iPhone 5 Teardown: adım 16, 2 resimden 1. iPhone 5 Teardown: adım 16, 2 resimden 2.
    • Now for the plat de résistance: the A6 application processor.
    • The A6 processor is the first Apple System-on-Chip (SoC) to use a custom design, based off the ARMv7 instruction set.
    • Because the A6 is not an ARM-specific CPU design, this gives Apple the ability to tailor the A6 towards their needs.
    • According to Chipworks, the B8164B3PM silkscreen label denotes 1GB Elpida LP DDR2 SDRAM.
    • Contrarily, the infographic presented during Apple's Keynote clearly showed Samsung RAM (K3PE7E700F) in the A6.
    • Not too long ago, Apple decided to reduce the number of RAM chip orders from Samsung. Time to invest in Elpida? Or is Samsung lurking in the next phone on the shelf? That's for you to decide.
  17. iPhone 5 Teardown: adım 17, 1 resimden 1.
    • Did someone ask for a close-up of the Apple 338S1077 Cirrus audio codec?
    • What exactly does an audio codec do? In short, it's a single device that acts as both a digital-to-analog and analog-to-digital converter to properly encode and decode audio in and out signals.
    That is Apple 338S1077 Speaker ic,Apple 338S1117 Cirrus Logic is the Audio Codec!
    Filip Pusca - Yanıt
    Dear people if you disassemble an device never use tools to pry up any connectors flexes, use your finger nails to exclude damage of SMD parts,some people guided to use such tools when take off GPS flex cable on iPhone 5 they damage IMEI ic which stay in corner of simholder after that ic damages you can trash your phone,and there are many other faults caused by such tools so be careful!
    Filip Pusca - Yanıt
  18. iPhone 5 Teardown: adım 18, 1 resimden 1.
    • Chips on a board. Kinda like ants on a log.
    • STMicroelectronics LIS331DLH (2233/DSH/GFGHA) ultra low-power, high performance, three-axis linear accelerometer
    • Texas Instruments 343S0628 touch screen SoC
    • Broadcom BCM5976 touchscreen controller
    • Rather than a single touchscreen controller, Apple went with a multi-chip solution to handle the larger screen size, à la iPad.
    • Apple A6 application processor
    • Qualcomm MDM9615M LTE modem
    • Qualcomm RTR8600 Multi-band/mode RF transceiver, the same one found in the Samsung Galaxy S III
  19. iPhone 5 Teardown: adım 19, 1 resimden 1.
    • An iPhone with 4G connectivity? It's more likely than you think.
    • We can now confirm that the Qualcomm MDM9615M is the 4G LTE modem powering this new feature.
    • After being teased for over a year by Android bullies, the iPhone faithful finally have 4G LTE on their side. What will they do with this newfound power? Only time will tell.
    • The Qualcomm MDM9615M is a 28 nm LTE (FDD and TDD), HSPA+, EV-DO Rev B, TD-SCDMA modem.
    • The MDM9615 allows for multi-spectrums, multi-mode LTE support. It is responsible for transmitting simultaneous voice and data transfer on LTE (provided the carrier has the infrastructure to allow simultaneous voice and data transfer.)
    • We also find the Qualcomm RTR8600 multi-band/mode RF transceiver. The RTR8600 is paired alongside the MDM9615 to support various bands, including 5 UMTS bands, and over 5 LTE and 4 EDGE bands.
  20. iPhone 5 Teardown: adım 20, 1 resimden 1.
    • Here's a closer look at the Broadcom BCM5976 trackpad controller.
    • Apple used this same chip in the MacBook Air to control the trackpad. Here, it's working together with the Texas Instruments touchscreen controller to take care of touch inputs on the Retina display.
  21. iPhone 5 Teardown: adım 21, 3 resimden 1. iPhone 5 Teardown: adım 21, 3 resimden 2. iPhone 5 Teardown: adım 21, 3 resimden 3.
    • After completely dissecting the logic board, we turn our attention back to the rear case.
    • Not even a healthy heap of adhesive can stand up to our mighty spudger!
    • The Lightning connector assembly, which includes the headphone jack, loudspeaker, and lower microphone, comes out next.
    • It appears that the Wi-Fi antenna is also embedded into the assembly. The iPhone 5 now includes support for 2.4 GHz and 5 Ghz.
    • Antennas are sized to be fractions of full wavelengths, so the 1.23" of a quarter 2.4 GHz wave is close enough to the 1.18" of a half 5 GHz wave that a single antenna can serve both frequencies.
    So you still haven't updated this about the Wi-Fi antenna? There's already another guide telling where the Wi-Fi antenna is. The Murata Wi-Fi module is far from the speaker so this coaxial connector should belong to mobile phone functions. iPhone 5 Wi-Fi Antenna Replacement
    Wayne - Yanıt
    I think you mean that the antenna has to be a "harmonic" of the wavelength, not just a "fraction." Big difference.
    bob - Yanıt
  22. iPhone 5 Teardown: adım 22, 1 resimden 1.
    • The first of three microphones comes out of the iPhone 5 along with the Lightning connector assembly.
    • It is safe to assume that the microphone located at the bottom front of the device is used for voice commands and voice calls.
    • The other two microphones remain in the device, for now, waiting towards the top of the phone.
  23. iPhone 5 Teardown: adım 23, 3 resimden 1. iPhone 5 Teardown: adım 23, 3 resimden 2. iPhone 5 Teardown: adım 23, 3 resimden 3.
    • The Lightning connector looks like it could be swallowed by the the 30-pin dock connector.
    • Here we can clearly see the eight leads in the new Lightning connector.
    • While there hasn't been any official word on the pin-out for the Lightning connector, we can confidently say that two of them will be used for power and ground. As for the other six, well, that's anyone's guess.
    • Update: We now know what the pin-out of the Lightning connector is.
    • Apple claims that the Lightning connector is all digital. However, they also claim that the iPhone 5 supports analog audio-out and VGA video, indicating that there may be some kind of digital-to-analog conversion going on inside the cable.
    Everyone seems to focus on the connector, but it's the socket that makes for a smaller device. What is the difference in area and volume between the 30-pin socket and the Lightning socket.
    Gary - Yanıt
    As for conversion D/A and A/D in a Lightening cable,(to support analog A/V output) it is also possible that the port is mode sensing. I have seen a number of devices now that mode sense on USB ports to provide analog A/V out, as well as USB/OTG functions depending on which cable is plugged in.
    Brian - Yanıt
  24. iPhone 5 Teardown: adım 24, 3 resimden 1. iPhone 5 Teardown: adım 24, 3 resimden 2. iPhone 5 Teardown: adım 24, 3 resimden 3.
    • Further investigation into the Lightning connector shows a neat array of pins and a clip to hold the cable in place.
    • As can be seen in the 2nd high res picture, there are are two outermost pin that are inset from the others. This is standard practice to insure that all other signals and power are connected before the ground or power (depending if Apple decided to supply power via the outer metal shield or ground.
    • Normal practice is to connect signals and ground first and then the power is applied via the shorter pins. Time will tell and someone with a DVM as to which is the power (pin or shell).
    • Each pin (shown in the third picture) is springy and gold plated on the end to ensure good conductivity between the Lightning cable and the socket.
  25. iPhone 5 Teardown: adım 25, 3 resimden 1. iPhone 5 Teardown: adım 25, 3 resimden 2. iPhone 5 Teardown: adım 25, 3 resimden 3.
    • Even with several components remaining, the back case is impressively light.
    • Using a high tech, advanced precision scale, we conclude that the entire rear case of the iPhone 5 weighs only slightly more than just the glass rear panel of the 4S.
  26. iPhone 5 Teardown: adım 26, 1 resimden 1.
    • Pressure contacts on the vibrator motor mean that replacing it doesn't require soldering or prying up small connectors.
    • Unlike the iPhone 4S, which used a linear-oscillating vibrator, Apple has gone back to a rotational motor with a counterweight.
    • We praised Apple in the past for going with the quieter and less annoying linear oscillating vibrator (Which is made by Samsung), but now we're scratching our heads as to why they went back.
    You could barely feel the linear oscillator. I'm glad they went back to the rotational motor. At least now you'll be able to feel it vibrating in your pocket.
    Hayden Boroski - Yanıt
    I think this patent (below) is the reason Apple no longer uses a linear oscillator. Oh and who owns the patent I hear you ask? A: Samsung.
    http://www.google.com/patents/US20040130...
    Nick Gilbert - Yanıt
    I agree, the linear oscillator is terrible. Sure, its quieter, but you can hardly feel it. I definitely missed more calls with my 4S than any previous phone. Also, the rotational motor is smaller than the linear oscillator.
    nbidgood - Yanıt
  27. iPhone 5 Teardown: adım 27, 1 resimden 1.
    • The ear speaker comes out easily with two screws and connects to the display assembly with spring contacts.
    • The speaker in the iPhone 4S was adhered to the fragile power button ribbon cable and required a lot of work to remove. Now it pops right off the display assembly—another hooray for repairability!
  28. iPhone 5 Teardown: adım 28, 2 resimden 1. iPhone 5 Teardown: adım 28, 2 resimden 2.
    • Apple's newest iteration of its classic home button sports an integrated metal support bracket, which we hope will greatly strengthen the oft-used switch.
    • Many iPhone 4 and 4S users have experienced the woes of a faulty home button, but haven't been brave enough to attempt the repair. This new design should not only increase longevity, but also make replacing the home button a lot less of a hassle.
    • A side-by-side comparison of the iPhone 4 and iPhone 5 display assemblies. The iPhone 4s has an integrated home button.
    Hi. On photo 28, those pair of contacts on printed pcb from the home button are going to be connected to a pair of contacts-springs that are near the lightning connector. Where do these contacts-springs are connected to ? I have a case of faulty home button that after replacing the home-button assembly, it is still failing. What could be the cause ? I’ve read that the home button when it fails, 9 out of 10 cases is due to the button itself. My case is 10% remaining. Any idea? Thanks.
    Carlos - Yanıt
    Just for clarification. The pair of contacts-springs that I mentioned before, are visible on photo of step 21
    Carlos - Yanıt
  29. iPhone 5 Teardown: adım 29, 1 resimden 1.
    • What first appeared to be part of the LCD assembly is easily removed after the turn of a few screws.
    • This plate is likely used for shielding and heat dissipation. The spring contact near the screw suggests that the plate could also be used for grounding.
    • We've had some inquiries if this shield was made of Liquidmetal. Sorry to disappoint, folks, but it doesn't seem to be that alloy. The plate has the same resistance of stainless steel and is slightly magnetic, just like stainless steel.
  30. iPhone 5 Teardown: adım 30, 2 resimden 1. iPhone 5 Teardown: adım 30, 2 resimden 2.
    • Based on a user request, we looked into the concerns about "Scuff Gate," the fear that the black coating scuffs off too easily.
    • We found that the side is pretty tough, but the chamfered edge can be susceptible to scuffing, making for a shiny streak on the side.
    • Moral of this story: be careful, or get a case. Or be free like the wind and just don't care.
    Good point! more of us need to learn how to be free like the wind.
    Collin Reisdorf - Yanıt
  31. iPhone 5 Teardown: adım 31, 2 resimden 1. iPhone 5 Teardown: adım 31, 2 resimden 2.
    • One of the iPhone 5's biggest selling points was the updated 8 megapixel iSight camera.
    • Although it's hard to see many differences between this camera and last year's model on the outside, Sony made some significant upgrades, including improved low light performance and 40% faster image capture. iPhone 5 camera is on the left.
    • Will your pictures be this good? That depends—will you take the time to snap photos of something besides your dinner?
  32. iPhone 5 Teardown: adım 32, 2 resimden 1. iPhone 5 Teardown: adım 32, 2 resimden 2.
    Satın Al
    • Apple was very proud of the fact that they are using a sapphire crystal in their new-and-improved camera.
    • Since sapphire is such a hard material, it would be sensible that the outermost element of the camera is made of sapphire.
    • We tried scratching the clear cover with a pair of steel tweezers and the lens remained scratch-free.
    • While this doesn't confirm that the protective cover is made from sapphire crystal, it does mean that it is quite hard and scratch resistant.
    • After giving it some thought, we decided that a few passes with a pair of tweezers wasn't a sufficiently thorough scratch test for the camera lens coating.
    • The rear case of the iPhone 5 doesn't hold up well to a barrage of sandpaper and keys, but the lens cover remains crystal clear. Wow.
  33. iPhone 5 Teardown: adım 33, 2 resimden 1. iPhone 5 Teardown: adım 33, 2 resimden 2.
    • We have found them! Just as Apple promised, there are more microphones residing in the top of the device.
    • First, we find the front facing top microphone, presumably for FaceTime and speakerphone capabilities.
    • And on the back? It's starting to look like a triple microphone! The rear-facing microphone partners up with the rear-facing camera for recording video, and is also used for canceling out background noise when on calls.
    My amend suggesting the purpose of the rear mic was deleted by Brett, but the rear mic is *definitely* used for recording sound when filming video. To verify, blow on the mic during recording, then temporarily cover it with your finger for comparison. Covering this mic with your finger totally mutes the wind noise.
    I m having camera n cellular network problemin my iPhone 5, can someone tell me how to fix it. Email me waleeddhch or whatsapp me 0345-4494079
    waleedbch - Yanıt
  34. iPhone 5 Teardown: adım 34, 2 resimden 1. iPhone 5 Teardown: adım 34, 2 resimden 2.
    • iPhone 5 Repairability: 7 out of 10 (10 is easiest to repair)
    • We're quite happy that the glass/display is the first thing that comes off the iPhone 5. The majority of iPhone repairs are due to a shattered front glass.
    • The battery comes out with a bit of prying once the front panel is removed.
    • The iPhone 5 still uses Pentalobe screws on the exterior, making it more difficult to open the device.
    • The front glass, digitizer, and LCD are all one component, thereby increasing cost of repair.
    • Lots of smaller components are soldered to one ribbon cable, increasing the cost of repairing just one component.
    I'm very happy to see Apple including a SIM card tool again, but how do you get the nanoSIM to stay in the full-size holder?
    Kit Halsted - Yanıt
    What about removing the top and bottom panels of the rear casing? What are they? What are they made out of? How are they removed?
    Phil - Yanıt
51 Yorum
Keep it coming guys...great.
Juan Bobby - Yanıt
Please remove all the cans so we can see the baseband, transceiver, antenna setup, etc... Thanks!
JaCar - Yanıt
Great job .. this is what exactly i was waiting for
prakash dahal - Yanıt
AMAZING! Thanks for getting this out there! I've suspected that this phone was going to be easier to replace the screen ever since the leaked parts started pouring in.
Thank God it's not like the iPod Touch 4th Gen display.
When are you going to do a tear-down on the 5th Gen iPod touch?
justfinethanku - Yanıt
cool and looks so nice too
Kwame Owusu - Yanıt
It's great job.
Please remove all black color label on the battery, to identify more details, Thanks
Masa - Yanıt
Excellent description and beautiful photos as always. You folks do an excellent job.... with one minor request for more... The details of the antennas are not clear. In particular, where exactly are the 3G/4G antennas? Is the metallic ring around the perimeter of the phone part of an antennae again as in "antennagate?" (I don't think so, but would like confirmation). Also, are the diversity antennas used over all the bands?
Stephen Wilkus - Yanıt
Have you opened the lightning cable? Seems to be an authentification chip inside..
3gfisch - Yanıt
quick one: which chip is used for GPS and does it dual GPS/GLONASS as it was in 4S?
Alexander Zuev - Yanıt
Is the LCD & Lens separate like the 3G/GS? Or, is it put together as one piece like the 4/4s?
Scott - Yanıt
is it possible to remove the glass/ceramic sections on the rear case,
to allow a black front case, and black rear sections, to be fitted into a silver iphone?
jimbo - Yanıt
Any chance you can acually rate the repairability of Samsung Galaxy S3 as well? Seems kinda weird that you "don't feel it's right to judge a device through the intertubes" only for that one...
Nick - Yanıt
Omg coming from fixing over a dozen 4's this is amazing for fixing a cracked front screen, I seriously think I'm gonna run around the block naked and rejoice!!!! THANK U APPLE!!!!!
JAWNPAWN - Yanıt
What kind of plastic does the iPhone 5 casing use? (The part that connected to the aluminum stripe across the back). I dropped my phone down some stairs and the plastic part cracked.
Edward - Yanıt
Sadly, those parts in the rear case are glass, so there isn't much you can do to fix them short of replacement. Check out this Answers post about taking those parts out.
Andrew Optimus Goldheart -
apple的产品是我见过内部构造最复杂的了。。。。。
GaoYuming - Yanıt
Looks like Chipworks has their teardown up: http://goo.gl/H65BgS
Phil - Yanıt
Hi I have water damage on my iPhone 5 and I would like to fix it.
I've read your water damage guide and I didn't understand if you can/have to clean all the parts where there's some corrosion visible or just the logic board and LCD? Will it help if I clean everything with a cloth moistened in isopropyl alcohol?
Thanks, and I commented here because the last article about water damage is very old and outdated it's on the iPhone 3G so I posted on this active guide.
Noel - Yanıt
Thanks for the post. There are so many little pieces inside that little phone! I loved how one of the pieces says "Apple Kor." Thanks for the teardown.
Rachel Zane | http://www.accuratewesternscale.com/prod...
rachelzane1809 - Yanıt
wow i have just finished replacing my iphone 5 screen scary at first but not so complicated. make sure you dont drop any screw, the suction pad didnt work for me, i had to pry the bottom screen, do it gently so you dont leave any marks on the phone. once out every thing is straight forward, carefull with the home button, on mine it was stuck on original phone with adhesive. so taking out the flat cable was a delicate process. other wise phone is brand new and works well and look brand new. thanks Ifixit.com
mwanzie - Yanıt
Where to find the quartz oscillator?
nihatozkan94 - Yanıt
Thanks for the info sharing with us!!!
indeedparts.com
michaelD - Yanıt
I'm very happy to resove my problem [url=http://www.bigophonepascher.com//]Galaxy S4 pas cher[/url]
onsebigophone - Yanıt
i need help wit the 821-1441-a pcb antenna switch , i want a tutorial how to remove and install a new one , some1 can help!?
Chris - Yanıt
What kind of plastic does the iPhone 5 casing use? (The part that connected to the aluminum stripe across the back). I dropped my phone down some stairs and the plastic part cracked. Can i use this parts <a href="http://www.makibadi.com/acheter-telephon... rel="nofollow">Accessoire iPhone 6/</a>
alicebertaux - Yanıt
This part will also fix a broken home button if the little copper contacts have been ripped off by a co worker that messed with your broken down phone after you told him not to
Athena Strong - Yanıt
Hi who is the author of this? I would like to cite it in my project.
thanks! :-)
Nick - Yanıt
I have a problem in My iPhone 5! It do not recognize da the original Lightning cable charge or usb on the computer.. I already try to change the conector... Is saem thing in the main board! Sorry about My english! Please help!
Fernando De Martino - Yanıt
The iPhone 5 was the most beautiful iPhone, especially the silver one. It was the the lightest until now and quite fast. I wished I hadn't sold mine. It was the last iPhone Steve Jobs commissioned. It is just beautiful, elegant and light. Very fast on the iOS 10 with long battery life. I like the headphone jack.
Cosmo Karma - Yanıt
informative post!!! thanxx for sharing .do give a post on iphone 7
lily cyrus - Yanıt
i can't stop laughing at step 12
Cheer !
Đô Phạm - Yanıt
it is really helpful for me since i started my repairing please keep going on and thanks a lot for helping individual repairer to run their shops.
thanks again ifixit you are doing great job for no cost. ummmaaah
saif ullah - Yanıt
اين اجد مذر بورد ايفون 4s?
Jaman - Yanıt
My iphone 5 have a problem when it is turned on it works properly but when its battery drain to zero and phone turned off then it don't picking up charging.Help me.
Punjabi Club - Yanıt
Excellent guide. Please tell me if I don't have several tools, can I take it apart completely? I can't do step 29. My friend from <a href="https://papercheap.co.uk">papercheap</a> did it easy.
prome.4 - Yanıt
Very useful information about 45 and 3G networks We look forward to articles about what is 5g networks. 5G networks The latest network technology and the latest research, 5G should provide much faster connections than current networks where, with average download speeds of about 1 Gbps Allow a speed of about 10 GB.
jamal - Yanıt
Let’s Grow Together is your Health and Cares website. We provide you with the latest Tips and tricks of health and cares and videos straight from the Cares industry.
read full article on https://healthpartners01.blogspot.com/
Viral lol - Yanıt
Very nice blog and the information shared by you is very useful to the users like me thanks for sharing it and keep up with the good work.
<a href="http://cracedkey.com/"> cracedkey </a>
Abdul Rehman - Yanıt
This is a great article. Detailed information has been studied before on https://foxmoney.com.ua/kredit-bez-paspo...
Григорий Малышов - Yanıt
<a href="https://tecvase.com/ymail-sign-up-create... data-type="URL" data-id="https://tecvase.com/ymail-sign-up-create...>A Ymail account</a> offers you the opportunity to access other Yahoo products. But to sign up for Ymail, you need to have some information with you. This information is what Yahoo uses to keep your account safe and secured.
Football Gist - Yanıt
Dear All Visitors '''softwarebig.com''' is the Best Place to download the PC software, s Free of cost & With Serial key, Keygen, Crack & Full version you are also downloading the Android Games & Latest Android APPS.  We are updating our site daily with the latest version.  We are giving all software With Direct Download Links.
Software Big - Yanıt
'''Grammarly Crack 2021''' is really Lucky for you personally our team lately had use of each of your beloved Grammarly Premium Accounts Cracks. We’re very happy to tell each one of you a major number of completely free grammar premium balances. No downloads samples or suggestions are available, and before discussing, we make certain that every account will do the job.
To sign in your Linksys device, type the Linksys default IP address 192.168.1.1 into the browser.We are providing best solution for your all linksys router and extender. for more information .<a href="https://linksysvelopsetup.com/">Visit on</a>
belkin router - Yanıt
Thanks for share this blog.........i am not a regular internet reader but now am reading daily read your blog..please also <a href="https://www.httpmyrouterlocal.net">Visit on</a>
This i Phone is very good for IPTV channel streaming iptv m3u
Tony Thomas - Yanıt
A very good post calcul mensualité crédit for sharing !
Sophie Amory - Yanıt
Any ideas?
I replaced the battery and the screen on my daughter’s iPhone 5. Now the mic does not work on normal voice calls. Speaker phone works fine, just not ordinary voice calls. Has anybody got a suggestion as to where I should begin looking?
Ian Wales - Yanıt
Really enjoyed Reading this! Helped med out big Time.. good work
Patrick Dahl - Yanıt
ROM download reference and mobile and computer training
https://aryarom.com/
rogueone417 - Yanıt
How to re assemble it set it to the position it was on before
Maxem - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 124
Son 30 gün: 576
Her zaman: 1,612,834
