Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. iPhone 8 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iPhone 8 Teardown, iPhone 8 Teardown: adım 1, 1 resimden 1.
    • The 8 has some slick new tech, but is it enough to warrant the upgraded digit? You be the judge:
    • A11 Bionic chip with embedded M11 motion coprocessor
    • 64 or 256 GB onboard storage capacity
    • 4.7-inch IPS multitouch Retina HD display with 1334 × 750 resolution (326 ppi)
    • 12 MP camera with ƒ/1.8 aperture, optical image stabilization, and 5x digital zoom
    • 7 MP FaceTime HD camera with ƒ/2.2 aperture and 1080p HD recording capability
    • Support for fast-charge and Qi wireless charging
    • 802.11a/b/g/n/ac Wi‑Fi w/MIMO + Bluetooth 5.0 + NFC
  2. iPhone 8 Teardown: adım 2, 3 resimden 1. iPhone 8 Teardown: adım 2, 3 resimden 2. iPhone 8 Teardown: adım 2, 3 resimden 3.
    • As we start our teardownunder we're greeted by a now-familiar face. Features include:
    • Solid-state home "button" with Touch ID fingerprint sensor.
    • A (still) IPS display similar to the one we found in the iPhone 7 (but now featuring True Tone).
    • On the backside, we spy the iPhone's snazzy new glass backing with its seven-layer color finish.
    • Apple assures everyone that this rear panel is reinforced with "an internal laser-welded steel and copper structure," but time and durability tests will tell if this phone will suffer from a snap, crackle, pop—or yet another Bendgate.
    • Jury is still out on the model number and the missing wheely-bin symbol.
    • Finally, before getting to work, we take a second to line up our new gold iPhone 8 and yesteryear's rose gold 6s. Apple has certainly refined (and re-refined) this design, in addition to stripping a little pink from the finish.
  3. iPhone 8 Teardown: adım 3, 3 resimden 1. iPhone 8 Teardown: adım 3, 3 resimden 2. iPhone 8 Teardown: adım 3, 3 resimden 3.
    • Before we excavate, we X-ray!
    • Our pals at Creative Electron came down under to Circuitwise and snagged some stellar sneak peek imagery.
    • The seamless back gives way to some intricate insides. The first thing we spy is the brand new wireless charging coil!
    • More on that later. For now, we put down the X-ray goggles to plan our attack.
    • Turns out you don't need X-ray vision to see the model number on this blank-backed phone—it's here on the rosy gold box—A1863!
    • It seems that when Apple set out to clean up the back of the iPhone, it decided to follow all the way through. We're guessing we won't find a cute ID card in the SIM tray, though.
    • Time to get this teardown underway. After twirling away the pentalobe screws, we need some heat as an antidote to the waterproof display seals.
    • iOpener—bam! Seals softened. Next we pull the iSclack out of our tool bag for some pulling power, and slice through the adhesive with a little help from our friends opening picks.
    • Do you ever have déjà vu?
    • ... and we're in! A first glance reveals nothing new—yet. But we've only just scratched the glassy surface.
    • As we crack open this book display, we are greeted by the familiar display cable bracket. But instead of the cursed tri-point screws, we're happy to report that we're met with friendly Phillips #000 screws!
    • We can't say that we will miss you, tri-points.
    • We quickly decouple a few cables—the battery, display, and home button cables to be exact—and the display is free!
    • We note a lack of gaskets on the display's pentalobe tabs, which was previously seen in the iPhone 7.
    • However, both the iPhone 7 and iPhone 8 have an IP67 water resistance rating. How are the floodgates still closed!?
  4. iPhone 8 Teardown: adım 6, 3 resimden 1. iPhone 8 Teardown: adım 6, 3 resimden 2. iPhone 8 Teardown: adım 6, 3 resimden 3.
    • We make a grab for the battery's stretch-release adhesive strips, and find there are two more of these guys than we're used to.
    • But that's okay—we just ask for a hand (or two), and remove all four at once!
    • This procedure requires a wealth of experience, gained in large part due to Stretch Armstrong.
    • We easily throw back the mozzarella sticks pull tabs as the battery springs free effortlessly.
  5. iPhone 8 Teardown: adım 7, 2 resimden 1. iPhone 8 Teardown: adım 7, 2 resimden 2.
    • Now that this juicy battery pack is out, we can see how it compares to its competitors!
    • Fully topped off, this 3.82 V, 1821 mAh cell will deliver up to 6.96 Wh of power.
    • To compare Apples to Apples, the iPhone 7 featured a 7.45 Wh battery.
    • And for reference, the similarly-spec'd Galaxy S8 packs a 11.55 Wh battery.
    • Before you get hopping mad about battery news: despite the drop in capacity, Apple claims battery life will be comparable to last year’s unit.
    • We pluck the main camera in pursuit of the logic board.
    • The iPhone 8 has the same ƒ/1.8, 6-element lens that we saw on the iPhone 7, but everything else about the camera is new and improved.
    • The 8's sensor is bigger than the 7's, but specs the same 12 MP resolution. This means the individual pixels are larger—letting in more light, improving colors, and decreasing noise.
    • But wait, there's more! Improved image processing software shows Apple still has a few clever tricks up its sleeve.
    • We've seen this before, but not with the naked eye! Neat X-rays reveal magnets in the four corners of the camera—giving this camera some advanced vision of its own through OIS.
    • As our quest continues, we find some quirky cables and brackets!
    • First out: a new Lightning port bracket that seems to reinforce the new peach-colored port and trap the Taptic engine.
    • Up to now, we've gleefully plugged along with our Phillips screwdriver—but alas, all good things must come to an end. In removing this bracket, we encountered our first tri-point screw. Still, it's no match for our 64 Bit Driver Kit!
    • We suspect that the newly colored Lightning port could be made of a heat-transferring plastic to allow for safer fast-charging. (Or, it could just be color-matched to the chassis.)
    • Next: a strange interconnect/antenna cable over the speaker.
    • Finally: the Taptic Engine nestled in a series of tiny fiddly connectors.
  6. iPhone 8 Teardown: adım 10, 2 resimden 1. iPhone 8 Teardown: adım 10, 2 resimden 2.
    • The final barrier to logic board gold: this tiny hidden screw, which we find trapped under the waterproof silicone seals!
    • We get another helping hand in the form of Jumpy's for logic board removal!
    • Kangaroo-shaped, chicken-flavored snacks aside, we hope you're not jumpy for the iPhone X. Reports say that production could start as late as mid-October—meaning the 8 could be the hardware of choice for early upgraders as well as those in Apple's Upgrade Program.
  7. iPhone 8 Teardown: adım 11, 3 resimden 1. iPhone 8 Teardown: adım 11, 3 resimden 2. iPhone 8 Teardown: adım 11, 3 resimden 3.
    • Drumroll please—it's chip time! Special thanks to the folks at TechInsights for helping scope out this silicon:
    • Apple 339S00434 A11 Bionic SoC layered over SK Hynix H9HKNNNBRMMUUR 2 GB LPDDR4x RAM
    • Qualcomm MDM9655 Snapdragon X16 LTE modem
    • Skyworks SkyOne SKY78140
    • Avago 8072JD130
    • P215 730N71T, likely an envelope tracking IC
    • Skyworks SKY77366-17 quad-band GSM power amplifier module
    • NXP Semiconductor 80V18 (PN80V) secure NFC module
  8. iPhone 8 Teardown: adım 12, 2 resimden 1. iPhone 8 Teardown: adım 12, 2 resimden 2.
    • And on the back side:
    • Apple/USI 170804 339S00397 WiFi/Bluetooth module
    • Apple/Dialog Semiconductor 338S00309 PMIC and Cirrus Logic 338S00248 audio codec and 338S00286 audio amplifier
    • Toshiba TSBL227VC3759 64 GB NAND flash storage
    • Qualcomm WTR5975 Gigabit LTE RF transceiver and PMD9655 PMIC
    • Broadcom BCM59355—Likely an iteration of BCM59350 wireless charging IC
    • NXP CBTL1612A1—Likely an iteration of the 1610 tristar IC
    • Skyworks 3760 3576 1732 RF switch and SKY762-21 247296 1734 RF switch
  9. iPhone 8 Teardown: adım 13, 2 resimden 1. iPhone 8 Teardown: adım 13, 2 resimden 2.
    • IC Identification, continued:
    • Cypress Semiconductor CYPD2104C USB type-C port controller
    • Texas Instruments SN2501 li-ion battery charger
    • Texas Instruments SN61280E battery boost converter
    • Texas Instruments LM3539 LED driver
    • Texas Instruments TPS65730 ? display power management (likely)
    • Bosch Sensortec accelerometer/gyroscope
    • Bosch Sensortec BMPxxx ? pressure sensor
  10. iPhone 8 Teardown: adım 14, 2 resimden 1. iPhone 8 Teardown: adım 14, 2 resimden 2.
    • Logic board dispatched, we get down to brass tacks plastic bits. Today's bits feature the speaker and barometric vent.
    • As we learned last year, this barometric vent allows your iPhone to accurately gauge your altitude, while maintaining a watertight seal.
    • Another small spec bump: Apple touts that the speakers are 25% louder in the iPhone 8—although there is some debate as to whether it is noticeable.
    • The same dozen donut speaker holes line the bottom of this iPhone as the 7.
    • We also find familiar signs of waterproofing in the form of seals and little rubber gaskets.
  11. iPhone 8 Teardown: adım 15, 3 resimden 1. iPhone 8 Teardown: adım 15, 3 resimden 2. iPhone 8 Teardown: adım 15, 3 resimden 3.
    • The rear case is looking a little thin on components, but we still find a few pieces that invite inquiry.
    • The peach-colored Lightning connector looks like it has changed a li'l since the iPhone 7. Without getting distracted by the desert camo, we notice a new form factor. Better ingress protection, mayhaps?
    • We dig through some black tape that covers some copper tape that covers some black tape ... wait a second ...
    • That ain't just black tape, it's the elusive Apple-branded, Qi (pronounced "chee")-enabled wireless charging coil!
    • This coil uses an oscillating magnetic field to generate an alternating current. The alternating current is then converted to direct current—the magic juice that fuels the battery.
    • We take a stab at separating the rear glass, but after a lot of heat and wetwork, we've instead shivved our way under the reinforcement panel.
    • After more arduous stabbing, we finally get the seven-layer burrito glass sandwich off of the midframe.
    • This isn't what we thought Apple meant when they said the glass was stronger.
    • The process left the backing plate a bit bent out of shape—we have no idea how Apple plans to do this, but they seem to be keeping the secret squirreled away...
    • And no, we didn't let snails figure-skate on the back—that's glue. Lots of it.
    • This side-by-side reminds us of something we recently noted.
  12. iPhone 8 Teardown: adım 17, 3 resimden 1. iPhone 8 Teardown: adım 17, 3 resimden 2. iPhone 8 Teardown: adım 17, 3 resimden 3.
    • We finally turn back to the well-known display and pluck the final features away.
    • Goodbye home button.
    • Goodbye front-facing sensor cable.
    • Goodbye LCD shield.
    • Oh, but hey li'l chip we can't identify.
    • Once again, the light sensor is covered by a colored filter, which we believe assists the True Tone system.
  13. iPhone 8 Teardown: adım 18, 3 resimden 1. iPhone 8 Teardown: adım 18, 3 resimden 2. iPhone 8 Teardown: adım 18, 3 resimden 3.
    • That's all she wrote! Well, at least for now—we've got a few more words and photos in store for you in the next few days!
    • Thanks heaps to Circuitwise for hosting us at their sweet facility in Sydney. (Seriously, check out that sweeet soldering video.)
    • And big thanks to the Creative Electron team for providing some serious X-ray support!
  14. Son Düşünceler
    • The two most commonly replaced components, display and battery, remain straightforward to access with the proper knowledge and tools.
    • The addition of wireless charging means less strain on your Lightning port, a common point of failure.
    • Water and dust seals complicate repair, but make the need for difficult liquid damage repairs less likely.
    • The battery connector once again sports common Phillips/JIS fasteners—but you’ll still need up to four different driver types for many repairs.
    • The durability of the glass back remains to be seen—but replacements are likely to be very difficult.
    • The iPhone’s lower components, once readily removed, now lie trapped under a fussy combination of brackets and delicately folded flex cables.
    Onarılabilirlik Puanı
    6
    Onarılabilirlik 10 üzerinden 6
    (10 en kolay onarılabileni)
Adam O'Camb
190.255 İtibar
416 adet Kılavuz yazıldı
82 Yorum
Live stream it on twitch.tv or youtube!
Andrew spoelstra - Yanıt
Link anyone?
Matt Traynor -
It looks like it's the same screen as the iPhone 7, something like the iPhone 5S and SE, maybe?
Universo Técnico - Yanıt
Hopefully, although since the new one supports true tone, it may not. However, those sensors may not be integrated into the display and just be a part of the camera and speakerphone assembly.
Edit: also, the black stuff isn't present on any iPhone 7 displays Ive got, also, the top clip on the left side seems to be rounded off, while on my 7 displays, they have a little sharpish point coming out of each side.
Andrew spoelstra -
Also, on the 8 display, there is a little bit of text on a black bit of plastic which reads “F08+C”, on my 8 display, it reads “F06+A”
Edit: also there are metal clips at the top of the 8 display, on the 7 they're made from plastic
Andrew spoelstra -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 79
Son 7 gün: 528
Son 30 gün: 2,172
Her zaman: 710,350
