Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Laminating process of iPhone X OLED screen is much complicated than LCD screen. Fit OLED with TP for the first time, then fit OLED with 3D Touch for the second time. The whole process counts more than 15 procedures.
Bu teardown bir tamir kılavuzu değildir. iPhone X cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Test the iPhone X screen before tearing down. Run function test - Display; Touch; 3D Touch and Swipe-up. All going well.
    • Test the iPhone X screen before tearing down. Run function test - Display; Touch; 3D Touch and Swipe-up. All going well.
  2. Place the OLED Screen Assembly on the Heat Platform. Remove bezel slowly with Pry Piece and Glue Cleaner. Cut a plastic horn of the bezel with the blade if necessary and then remove bezel with Pry Piece and Glue Cleaner carefully.
    • Place the OLED Screen Assembly on the Heat Platform. Remove bezel slowly with Pry Piece and Glue Cleaner. Cut a plastic horn of the bezel with the blade if necessary and then remove bezel with Pry Piece and Glue Cleaner carefully.
    • Be careful with flex cables when removing bezel in the flex cable area.
  3. Place the OLED Screen Assembly on the Heat Platform. Separate the glass lens from OLED with cutting wire. We are working with one OLED flexible screen, so be careful with your handwork.
    • Place the OLED Screen Assembly on the Heat Platform. Separate the glass lens from OLED with cutting wire. We are working with one OLED flexible screen, so be careful with your handwork.
  4. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Glue removing for iPhone X screen can be applied with hand tearing
    • Glue removing for iPhone X screen can be applied with hand tearing
  6. Different from Samsung smartphones, iPhone X has its 3D Touch module adhered behind OLED backplane.
    • Different from Samsung smartphones, iPhone X has its 3D Touch module adhered behind OLED backplane.
    • Different from all iPhone previous versions, the 3D Touch module of iPhone X is bonded to the OLED panel.
    • To fully analyze its structure, we took a disruptive disassembly of the 3D Touch module.
    • The 3D touch and TP flex bonding are also separated after the disassembly.
  7. Here is the structure of iPhone X OLED screen.
    • Here is the structure of iPhone X OLED screen.
    • This video presents novelty, disassembly difficulties and structure analysis of iPhone X OLED screen.
    • Credit: REWA Technology
Phryne
3.062 İtibar
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 49
Son 30 gün: 311
Her zaman: 1,059
