Ana içeriğe geç
Bu söküm üzerinde çalışılıyor – Son değişiklikleri görmek için düzenli olarak yenile!
Neye ihtiyacın var
  1. iPhone dock Teardown, Getting started: adım 1, 2 resimden 1. iPhone dock Teardown, Getting started: adım 1, 2 resimden 2.
    • Start by flipping the dock upside down.
  2. iPhone dock Teardown, Removing the back: adım 2, 2 resimden 1. iPhone dock Teardown, Removing the back: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    Satın Al
    • Take your Jimmy and push it in between the bottom cover and the body. Push down to lift the bottom cover.
  3. iPhone dock Teardown, Getting the back off: adım 3, 2 resimden 1. iPhone dock Teardown, Getting the back off: adım 3, 2 resimden 2.
    • Carefully remove the clips on the side by pushing up with the Jimmy. If needed, use the plastic Opening Picks to keep the back piece from popping back into place.
    Note: make sure that you are lifting with your jimmy the deep-down metal part together with the upper plastic cover. Otherwise you’ll break it apart - it is connected with each other by the bellow described phillips screws.
    Filip - Yanıt
  4. iPhone dock Teardown, Looking at the dock: adım 4, 1 resimden 1.
    • Remove the dock completely from the plastic frame.
  5. iPhone dock Teardown, Peeling back the black sticker: adım 5, 3 resimden 1. iPhone dock Teardown, Peeling back the black sticker: adım 5, 3 resimden 2. iPhone dock Teardown, Peeling back the black sticker: adım 5, 3 resimden 3.
    • The silver adhesive is covering two Phillips screws at opposite ends of the dock. Peel back the adhesive on these areas and remove both screws.
  6. iPhone dock Teardown, Removing four Phillips 000 screws: adım 6, 1 resimden 1.
    • Remove the back plate once the screws are out.
    • Remove four Phillips #000 screws surrounding the Lightning connector.
  7. iPhone dock Teardown, Removing the Lightning connector: adım 7, 2 resimden 1. iPhone dock Teardown, Removing the Lightning connector: adım 7, 2 resimden 2.
    • A similar adhesive can be found covering the plug for the Lightning connector. Peel the adhesive back and gently lift the cable to disconnect the connector.
Nathan
386 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
is it possible to find the lighting connector, since I have one that fell and it got all twisted and damaged and it tore the connector
Uriel Ramos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 2,095
