Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. iPod Touch 2nd Generation cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iPod Touch 2nd Generation Teardown, Teardown: adım 1, 1 resimden 1.
    • The new iPod Touch comes in a smaller, transparent plastic case.
    • Someone asked if we should turn it on, or check out the new software before we took it apart. But we're just a little too eager for that.
  2. iPod Touch 2nd Generation Teardown: adım 2, 1 resimden 1.
    • Also included in the box:
    • Earphones
    • USB 2.0 cable
    • Dock adapter
    • Polishing cloth
    My IPT did not come with a polishing cloth doese every IPT come with one?
    Qman - Yanıt
  3. iPod Touch 2nd Generation Teardown: adım 3, 1 resimden 1.
    • As expected, the form has been updated to match the iPhone 3G's shapely curves.
    • Note that the antenna cover is also transformed. It was a rectangle on the 1st Gen Touch.
    Can i use a screwdriver to take the screen off
    Zach - Yanıt
  4. iPod Touch 2nd Generation Teardown: adım 4, 1 resimden 1.
    • Removing the glass display and touch screen digitizer combo.
    Guys, for anyone trying to dissemble their ipor, be very carefull, there is on the top left of the ipod behind the benzel, a very thin cable that connects the benzel to the mother board. If you trying to remove the benzel, do not lift it untill you got the tape out, then carefully lift the benzel, and unplug the cable.
    rodrigocortizo - Yanıt
    Hey, this is not easy... I've successfully broken the LCD on my ipt2g trying to fix a chip in the glass. the mistake occurred when i was initially popping it open. Ive spent the last two years of my life fixing cellphones for a radio shack and like to consider myself somewhat of an expert on using a pry tool to pop open anything. i made a noob mistake. the kind of simple ^@^^ i did on my first phones. this is simply not easy to do, applying to much force causes a violent opening, not enough and you fidget around until you slip up. go at it with purpose and a good mindset. hold it above something soft and never allow you hands to get sweaty. when you slip and break it, try to keep your cool and not kick a hole in drywall.
    xKOMx - Yanıt
    xKOMx... yo
    U R so right, this is no experience for the faint of heart, I use 3 guitar picks, have been modified, used to use the Nokia tool (I'm Nokia level III certified) stil, I've manage to open 3 of this iPods.
    GOOODDD, it's so difficult, please, be very careful, you'll find yourself replacing in the best case scenario the Digitizer.
    Good luck
    gonps - Yanıt
    Beware of cracking glass opps!
    computerri - Yanıt
    What wisth is the spudger? Where can one have one?
    cubytus - Yanıt
    For some reason the multi-touch stopped working after i started to remove the glass. should i pretend that i didn't try and mess with it and send it in for warranty repair or should i try again to take it apart? i don't know why it isn't working whether i nicked something or if somehow the glass isn't touching anymore or something silly like that.
    Floofy - Yanıt
    I've also cracked my sceen trying to get it open. :(
    bowei006 - Yanıt
    Cool. I cracked my bezel too. Why aren't there any written instructions or warnings? $65 mistake. Ugh…
    bizzbobb - Yanıt
    bizzbobb kullanıcısından alıntı:
    Actually, this warning is written across the top of the page:
    "Teardowns provide a look inside a device and should not be used as disassembly instructions."
    Andrew Bookholt - Yanıt
    What if you cracked your glass display cover can you fix it and how do you know if you cracked you LCD also?
    Qman - Yanıt
    i crack the LCD screen nd the bottom(down) sensors wont feel when i touch it above(top) does feel when i touch it, idk what do to lol
    andres - Yanıt
    Floofy kullanıcısından alıntı:
    did you figure out what you did...either i have done something different or similar!
    llaadd - Yanıt
    I luv this website but man what a bad set of instructions for #4. I have been repairing iPhone's for some time now and just tried my first iPod touch using these instructions....not only did I destroy the digitizer, I also destroyed the frame and the lcd! then I went to youtube and for the correct instructions. Im not blaming iFixit but a complete set of instructions would be very helpful!! oh and i still luv this site and I luv the tools I just bought off here!
    chargit - Yanıt
    chargit kullanıcısından alıntı:
    iPod Touch 2nd Generation Repair Manual.
    Walter Galan - Yanıt
    I dont understand it took me less than 45 mins to replace the digitizer and bezel and the contact was easy to connect btw i got the bezel and digitizer under $30 so look for a good seller!
    ewq - Yanıt
    Does anyone have any tips for removing the glass... I cracked mine... badly... using the same techniques...
    William - Yanıt
    really? 10 years and nothing? RIP now cracked the glass…
    Penguin - Yanıt
  5. iPod Touch 2nd Generation Teardown: adım 5, 1 resimden 1.
    • The bare LCD display.
    • Apple gives the size as 3.5 inches (diagonal) with a 480x320 pixel resolution at 163 pixels per inch.
    What is the function of the copper adhesive tape at the top of the LCd screen
    tony - Yanıt
    tony kullanıcısından alıntı:
    ground connection for the LCD, protects from static, etc, may also hold down something underneath!
    llaadd - Yanıt
  6. iPod Touch 2nd Generation Teardown: adım 6, 1 resimden 1.
    • There are no screws securing the LCD. Instead, it's held in place with a little double-sided tape.
    There are 6 screws connecting the metal baking to the back plate
    langdonpike - Yanıt
    wow #*#! u guys i broke the glass
    fufhubbin - Yanıt
  7. iPod Touch 2nd Generation Teardown: adım 7, 1 resimden 1.
    • Removing the metal backing.
    • The battery is held to the backing with two strips of light adhesive, but peels off easily.
    how do i remove the metal backing to remove the battery? do i need to buy one of your screwdrivers?
    Timothy Ostendorf - Yanıt
  8. iPod Touch 2nd Generation Teardown: adım 8, 1 resimden 1.
    • Disconnecting the display data cable.
    • Note the residue from the glue holding the battery to the metal backing.
    • This is getting exciting!
  9. iPod Touch 2nd Generation Teardown: adım 9, 1 resimden 1.
    • Removing the battery.
    • The WiFi antenna and circuitry are at the bottom of the image, near the thumb.
  10. iPod Touch 2nd Generation Teardown: adım 10, 2 resimden 1. iPod Touch 2nd Generation Teardown: adım 10, 2 resimden 2.
    • The large orange cable connects the WiFi antenna (upper left) to the logic board.
    • The size, shape, and characteristics of the cable prevent external noise from interfering with the digital signals as they travel along the device.
    • At the top of the picture above the battery is a metal cover. Underneath the cover is a Broadcom BCM4325 Wi-Fi and Bluetooth chip. Yes, that's right, Bluetooth! Apple has said nothing of this publicly.
    • This particular bluetooth chipset supports BT2.1+EDR. No word yet on whether the one Apple included supports A2DP, which would enable stereo headphones.
    • This chipset also offers FM support, but Apple has displayed zero interest in FM historically, and there are no signs of that trend changing.
    • Part numbers: BCM4325GKWBG CD0825 B76332 P40 SF
    Very interesting about the Broadcom chip. I wonder why Apple shut that functionality down? I mean, if it has bluetooth I could hookup a headset and use Fring with no problem.
    kd1s - Yanıt
    The bluetooth could be a way of tracking people or something i think someone is controlling my IPT because it will close out to the home screen in the middle of a game and that makes me mad anybody know why it does that and if it can be fixed?
    Qman - Yanıt
    Qman kullanıcısından alıntı:
    That is because Ram inside the device is getting so hot that it is nearly going to overheat so the ipod cleverly shuts down the application so it can free up RAM.
    technobot - Yanıt
    technobot kullanıcısından alıntı:
    an add: restart the device to really clear the RAM.
    DarkReaper - Yanıt
    I'm having freezing trouble while playing music using the external speaker. When it happens the left bottom of the iPod becomes really hot. It's in the region of that chip of step 13 with the white sticker. Do you know what is that?
    leandro - Yanıt
    That is because Ram inside the device is getting so hot that it is nearly going to overheat so the iPod cleverly shuts down the application so it can free up RAM.
    Its not because the ram is overheating, the device doesnt generate enough heat for that to even be a factor, its because the ram is getting full.
    Walker Quine - Yanıt
    Nothing about the RAM getting hot. It's just running low on memory. Apps start closing when the device has about less than 10 MB RAM available. But jailbreaking solves this, there are tweaks that allow for expanding virtual memory, e.g. iMemory Enhancer from Gumball Tech repo.
    DarkReaper - Yanıt
  11. iPod Touch 2nd Generation Teardown: adım 11, 1 resimden 1.
    • The other side of the wireless circuitry, battery, and logic board.
  12. iPod Touch 2nd Generation Teardown: adım 12, 1 resimden 1.
    • You can see the dock connector in the center and the headphone jack on the right.
    • Note the small gold "square" above the dock connector. It's actually a conducting spring that rests against the home button. The button acts as a switch, connecting the spring to ground (the dock connector) when it's pressed.
    Do you have to dissasemble the whole board just to get to the earphone jack? I need to replace it... it looks like it requires soldering?
    pteotexz - Yanıt
    pteotexz kullanıcısından alıntı:
    I have the same question.
    hal
    hal sandick - Yanıt
    Did anyone resoldered this? Is it difficult?
    yannis frederickx - Yanıt
  13. iPod Touch 2nd Generation Teardown: adım 13, 1 resimden 1.
    • The logic board.
    • We think the brown rectangle in the center is the speaker. It looks like the two wires in the orange ribbon cable on the right of it run to the new volume control dial.
  14. iPod Touch 2nd Generation Teardown: adım 14, 1 resimden 1.
    • The battery. 3.7 V Lithium-ion polymer, as expected. Apple part number 616-0404. No word yet on the mAh rating.
  15. iPod Touch 2nd Generation Teardown: adım 15, 1 resimden 1.
    • The logic board again, this time with (what we think is) the speaker removed.
    • The NAND flash memory is a Micron MLC chip: MT29F64G08TAAWP
    • The processor is an Apple-branded Samsung-manufactured ARM with SDRAM on the package, similar to the iPhone processor.
  16. iPod Touch 2nd Generation Teardown: adım 16, 1 resimden 1.
    • The end.
    Where does one purchase a replacement back panel?
    jgreengold - Yanıt
    Thanks! Broke mine down too, except i used a flat screwdriver and a pocketknife! :)
    not as clean as your teardown, but quite the same. Great job!
    charlie hansell - Yanıt
    Where might one purchase a new back plate?
    Koston Morin - Yanıt
3 Yorum
Broke the screen.
probaly should of used a hair dryer
Jackson Oliverio - Yanıt
i need all the parts of ipod touch 2nd generation
vegi.pavan9 - Yanıt
hard to do really
Cooper Elam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 44
Son 30 gün: 179
Her zaman: 667,648
