Ana içeriğe geç
iomega LDHD250-U Teardown
Neye ihtiyacın var
  1. iomega LDHD250-U Teardown, Remove Rear Screws: adım 1, 1 resimden 1.
    • Remember to power off and unplug the unit before opening it up!
    • Remove the two PH #0 Screws
  2. iomega LDHD250-U Teardown, Removing the cover: adım 2, 2 resimden 1. iomega LDHD250-U Teardown, Removing the cover: adım 2, 2 resimden 2.
    • After removing the back part of the unit, slide the front part out.
    • Remember to put aside the center part you removed
  3. iomega LDHD250-U Teardown, Removing the Hard Drive: adım 3, 3 resimden 1. iomega LDHD250-U Teardown, Removing the Hard Drive: adım 3, 3 resimden 2. iomega LDHD250-U Teardown, Removing the Hard Drive: adım 3, 3 resimden 3.
    • There are two ways to remove the Hard Drive
    • 1. Removing the 4 screws on the side of the unit
    • 2. Sliding the HDD back and then releasing it (my unit will not slide back)
    • The HDD can now be lifted out, unplugged, and replaced, upgraded, or keep it the same.
    • Pull up and unplug as the cables can break if too much force is applied
Sonuç
Nate Pritzker
431 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 1,086
